24 F Battery for my 65 Caliente
garch65
Post by garch65 »
Hey,
I've been slowly going through everything on my car, I ran into a problem finding a battery. I need a 24 f series battery that clamps on the bottom. I can't find a place that sells the battery with the lip on the bottom. I need advice from the Mercury enthusiast :)
I believe the battery size is 6.5 inches by 11"
I tried Sears, they have it but no lip on bottom to clamp too :shock:
Thanks,
Garch 65
Lip Ripper
Re: 24 F Battery for my 65 Caliente
Post by Lip Ripper »
I'd be shocked if East Penn "Deka" or the green ones didn't.
Rural King, or a tractor supply variant.
Lip Ripper
garch65
Post by garch65 »
Thanks, I will check on that.
I also need an original dome light, I made the mistake of trying to push it on... ugh and I'm old enough to know better!
Post by comethead »
I used an adapter bracket NPD sells that allows you to use any 24F battery-
https://www.npdlink.com/store/products/ ... -2868.html
You can make your own.
It slides under the tray and you use a 1967 style over the top bracket with 2 side j-hooks. NPD sells those too. Total was less than $15
garch65
Post by garch65 »
Thanks Joe!
Post by comethead »
No problem!
Here's the 67 mustang style battery hold down to use with that bracket
http://www.cjponyparts.com/battery-hold ... oC4G7w_wcB
