Is this a 67 Comet clutch pedal assy?
The Big Comets
Postby Jedeka » Mon Dec 02, 2013 5:27 pm
I bought this pedal assembly, bead blasted and primed them. Waiting for bearing kit from Mustang Steve. Want to make sure this is the correct pedal assembly for a 67 Comet. These were supposed to have been pulled from a 67 Fairlane. If this is correct, where can I find a new clutch pedal bumper shown in pic #1 ? Thanks.
Clutch pedal bumper
Jedeka
Re: Is this a 67 Comet clutch pedal assy?
Postby hotsauc333 » Mon Dec 02, 2013 7:29 pm
I think those are from a 66. I had the same issue with mine, the pedals I bought were a whole inch short from the firewall to the where they mount up with the steering column. The reason I know this is because in the second pic you posted where there are the holes there should be nuts that the bracket bolts to. I used my pedal hanger bracket (from my car) and put the brake and clutch pedals in it. Works great. Good luck
1967 comet 302 T5
1966 mustang 302 C4
hotsauc333
Postby poboyjo65 » Mon Dec 09, 2013 10:49 pm
I think this is the bumper you need??
http://www.ebay.com/itm/Ford-Mercury-55 ... 72&vxp=mtr
347, 4sp, 9''
Postby Jedeka » Tue Dec 10, 2013 7:33 pm
Poboyjo65, I saw those in a few searches, but my pad has a flat bumper pad on the pedal side. I'm told there are no reproductions being made.
Jedeka
Postby Jedeka » Sat Dec 14, 2013 10:19 pm
I came across a 1" clutch pedal firewall spacer that fits my pedal bolt spacing. If I remember correctly, my pedal brackets measure 13" front to back and by adding the spacer, I should get the pedals installed correctly. Has anyone seen the spacer I am talking about? I cannot get picture to upload.
Jedeka
Postby poboyjo65 » Wed Dec 18, 2013 8:09 am
here is another one for a mustang, looks similar.
http://www.mustangsunlimited.com/search ... r&x=8&y=17
347, 4sp, 9''
Postby Jedeka » Thu Dec 19, 2013 1:18 pm
That bumper looks the most promising yet. Thanks. I will see if it works, when it shows up.
Jedeka
Postby Jedeka » Wed Dec 25, 2013 5:24 pm
Received the 67-68 Mustang clutch pedal bumper but not correct one. Back to the drawing board.
Jedeka
Return to 66 - 69 Comets
