Is this a 67 Comet clutch pedal assy?
I bought this pedal assembly, bead blasted and primed them. Waiting for bearing kit from Mustang Steve. Want to make sure this is the correct pedal assembly for a 67 Comet. These were supposed to have been pulled from a 67 Fairlane. If this is correct, where can I find a new clutch pedal bumper shown in pic #1 ? Thanks.
- image.jpg (187.98 KiB) Viewed 2283 times
- image.jpg (232.11 KiB) Viewed 2281 times
- Clutch pedal bumper
- image.jpg (228.55 KiB) Viewed 2280 times
- hotsauc333
Re: Is this a 67 Comet clutch pedal assy?
I think those are from a 66. I had the same issue with mine, the pedals I bought were a whole inch short from the firewall to the where they mount up with the steering column. The reason I know this is because in the second pic you posted where there are the holes there should be nuts that the bracket bolts to. I used my pedal hanger bracket (from my car) and put the brake and clutch pedals in it. Works great. Good luck
1967 comet 302 T5
1966 mustang 302 C4
1966 mustang 302 C4
I think this is the bumper you need??
http://www.ebay.com/itm/Ford-Mercury-55 ... 72&vxp=mtr
Poboyjo65, I saw those in a few searches, but my pad has a flat bumper pad on the pedal side. I'm told there are no reproductions being made.
I came across a 1" clutch pedal firewall spacer that fits my pedal bolt spacing. If I remember correctly, my pedal brackets measure 13" front to back and by adding the spacer, I should get the pedals installed correctly. Has anyone seen the spacer I am talking about? I cannot get picture to upload.
here is another one for a mustang, looks similar.
http://www.mustangsunlimited.com/search ... r&x=8&y=17
That bumper looks the most promising yet. Thanks. I will see if it works, when it shows up.
Received the 67-68 Mustang clutch pedal bumper but not correct one. Back to the drawing board.
