Well I just picked up a 66 Caliente convertible. It needs a top, interior, and paint, and not much else (yeah, right). It has mid 80s lincoln wheels with 215/70R15 tires, and they rub the front of the front fenders, and not just turning. These aren't huge tires, but should they rub like this, or is there something wrong with the front end?
Any ideas?
thanks
Bryan
66 tire rub
My guess is the offset is wrong on the wheels, possibly shifting the tire too far out, not really good for your steering geometry, if you can get some differant wheels you might try them or at least test fit them.
Take it from me, with 10" wide wheels on my Jeep Cherokee and tons of offset it is hard on front wheel bearings but it looks cool
Se Ya,
Se Ya,
Did some checking and banging, and shifted the front fender a little bit forward, so it's at least bearable for now. The Lincoln wheels are 5.75 inches wide and they look okay on the car.
Big problem is with the driver's door; the lower hinge mount of the door (not the hinge) is tweeked, causing the bottom of the door to stick way out. The door functions, just doesn't look pretty.
Thanks
Bryan
Thanks
Bryan
The 15" tires are bigger than stock. My '66 Capri 2 door hardtop came with 14" tires and rims. I've read from many members here and on another forum about tires clearances (mostly rear) and have made my own conclusion to stay with the 14"'s to save myself the grief of monkeying around with that stuff...
just my two cents...
Rod
Rod
66 tire rub
I have 195/60R/15 on the front and 215/60R/15 on the rear mounted on 15' American Racing Torque Thrust D's with no clearance problems. They fill the wheel wells good and look better than the 14's. These are mounted on a
'66 Cyclone GT with stock ride height.
Butch[/img]
Butch[/img]
'66 Cyclone GT
I have 215/60/15 tires on the front and 235/60/15 out back on my 66 Comet 202. This was biggest tire combo I could fit on my car. I tried 235/60/15 up front, but they were too big and I had to step down to the 215/60/15 tires. The only problem I have is if I turn a sharp corner hard, the rear tire will rub on the wheel well lip.
I cannot seem to find my pipe stretcher and sky hook, did I put it behind my bucket of arc sparks??????
Problem solved! Found a nice, almost brand new, set of American Racing Torque Thrust Ds, including a spare. What a difference they make, like they were supposed to be on there. All four are 195/60R14, but it was too good of a deal to pass up. Now I have to figure out how to keep from scraping the rear bumper when leaving the driveway.
Bryan
Bryan
