Page 2 of 4
Re: Roy's Ride,,The California Caliente!
Posted: Fri May 13, 2011 11:57 am
by CALIFORNIA CALIENTE
BadBrad;Yes,that is my Comet in the May issue of Car [Chevy] Craft.CC approached me about 5 years ago about doing an article,they finally shot it last December. ROY.
Posted: Fri May 13, 2011 12:19 pm
by Bad Brad
That's awesome Roy! I have read that article like three times now. I think it's pretty cool that you built it off a 289. I bet thing sounds mean as hell!
Posted: Fri May 13, 2011 1:45 pm
Brad;it did,it is dead now,broke another block!! It ran a best of 10.67 at 127.56,normally 10.7-10.8.I used a 65,289 block,bored .060 with a 3.40 stroke,the last one filled with Hardblok to help support the bores,didn't work though.I would have liked to use an aftermarket block but my crank would not work with one.I'm building a 418" engine based on a 351W,.030 over with a 4.10 stroke,much better rod angles,should not have to twist this one as tight as my little engine so I hope it lasts longer!! ROY.
Posted: Fri May 13, 2011 3:14 pm
by Bad Brad
Ouch! Sorry to hear about the block, but I think the extra 60+ cubic inches are going to well enjoyed
Posted: Fri May 13, 2011 5:01 pm
Brad;I like your signature,VERY TRUE!!!!!!!
Posted: Thu May 26, 2011 6:46 pm
by SLCK64
Yup it is....
http://www.carcraft.com/featuredvehicle ... index.html
Cept they titled it with Ray not Roy, might wanna get ahold of them to change it.
Posted: Wed Jun 15, 2011 5:06 pm
by StPro
Roy is your jerico transmission a clutchless Cog type or a pro shifted Std.type?
Posted: Thu Jun 16, 2011 12:37 am
StPro;my Jerico is the clutch type,you can shift it clutchless but Jerico says it will last longer if you clutch it.I have a McLeod 'Softlok'[slipper style] clutch,and use an adjustable clutch pedal adjuster set just off of the floor,I just tap the pedal between shifts,leaving the gas on the floor.The trans/clutch combo has proven to be 2/10ths quicker and WAY more consistent [5 passes within 2 hundredths]than my Liberty Pro-shifted Toploader/Ram Metallic Clutch setup,plus it has survived two seasons.Neither trans is very street friendly! ROY.
Posted: Thu Jun 16, 2011 12:44 am
Posted: Thu Jun 16, 2011 12:53 am
by StPro
CALIFORNIA CALIENTE wrote:StPro;my Jerico is the clutch type,you can shift it clutchless but Jerico says it will last longer if you clutch it.I have a McLeod 'Softlok'[slipper style] clutch,and use an adjustable clutch pedal adjuster set just off of the floor,I just tap the pedal between shifts,leaving the gas on the floor.The trans/clutch combo has proven to be 2/10ths quicker and WAY more consistent [5 passes within 2 hundredths]than my Liberty Pro-shifted Toploader/Ram Metallic Clutch setup,plus it has survived two seasons.Neither trans is very street friendly! ROY.
Yea thats kinda what I thought about not too freindly on the street. I have been running transmission things through my head trying to decide on manual or auto. Auto is better for drag radials, but stick is mucho fun. Its a hard decision especially 5 top loaders in the basement
Posted: Thu Jun 16, 2011 1:52 am
StPro;my Comet has mostly been a stick except for a couple races in 2004.I broke a Toploader just weeks before taking the car on tour.A good friend loaned me a Mike's Ultimate C-4 and converter,did the swap,the Comet slowed down about 3-4 tenths,nothing wrong with the C-4 but the converter was wrong.I at least was able to finish out the tour[40th T-Bolt Reunion Tour]and go a few rounds.I put a Liberty Pro-Shifted Toploader in for the 2005 season,it lasted until the last race of the season and broke while in 3rd.I sent it in to Liberty,they upgraded it to the 'NEW' style,broke it three races later.Sent it back to Liberty,new main case,new face plated gears,new 3-4 fork,new shift rails,it lasted four races then grenaded and seized up in third gear!!! I almost crashed but the trans broke free and let the car roll again!!!I think the biggest issue was that I was using a 1800 lb base pressure plate and sintered iron puck style disc and an aluminum flywheel combo that was too unforgiving!! Even with all those issues I still prefer a stick,WAY more fun and they can be very consistent,no matter what the slush box racers say!!!ROY.
Posted: Tue Jun 21, 2011 1:00 am
by comethead
Roy whats the status on the motor change??
Posted: Tue Jun 21, 2011 1:21 am
Joe;I hope to install the engine tomorrow,as normal I'm still waiting on a couple of items,the shop ordered the wrong pan gasket and my new crankshaft uses a different key setup than stock[they didn't send any keys].I got the flywheel/clutch back Thursday evening,at least that is one more item here! ROY.
Posted: Thu Mar 22, 2012 12:03 pm
by B_Hix
I had no idea there was a celebrity in our midst
Nice CarCraft write up - Roy, yer the man - represent!
Posted: Thu Mar 22, 2012 10:13 pm
hey Roy what color is your car & were there any other shades of light blue in 65? Mine was originally light blue & my uncle bought a light blue one in 65. just wondering.
