FULL SPOOL
Posted: Wed Oct 18, 2023 5:10 am
by fryedaddy
i got me a full spool for my 9 inch rear.i might wait till winter to put it in,i have a couple other winter upgrades to do to it also.
Re: FULL SPOOL
Posted: Wed Oct 18, 2023 5:37 pm
Wow are you going to convert to a full time race car?
Re: FULL SPOOL
Posted: Thu Oct 19, 2023 11:56 am
by fryedaddy
my plan is to be able to trailer it to the track and still keep it tagged so i can drive it a little.
Re: FULL SPOOL
Posted: Thu Oct 19, 2023 2:59 pm
by Boss/Cyclone
Be careful on wet roads. I ran a spool for years, gets sketchy around corners especially on wet roads. But I will say that the Detroit locker replaced the spool with drove me crazy and I now have a torque worm locker that is great for a street car. But if you are just occasionally street driving on nice days and the rest at the track you'll enjoy the spool.
Re: FULL SPOOL
Posted: Fri Oct 20, 2023 9:40 am
by fryedaddy
i have only got caught in a rain a couple times in 40 years,i only get it out on nice days.i have never put a spool in anything before,im ready to give it a try.i think i will try launching it when i get it in,see what happens or find out where my alkalies heel is.
Re: FULL SPOOL
Posted: Mon Dec 04, 2023 3:06 pm
by fryedaddy
i got my axles out,they look good,splines,bearings and all.i also got my center section out and apart and i have my ring gear put on my new spool.i need to knock-press the carrier bearings on my spool and i will be ready to put it back together. the carrier is the heavy duty with the 3/4 bolts instead of 9/16.i was concerned that the passenger side axle might have twisted splines from so many one wheel peels,but it was in better shape than the drivers side axle. i cant wait to try it out.
Re: FULL SPOOL
Posted: Mon Dec 04, 2023 8:21 pm
by Boss/Cyclone
That is good news on your axle shafts. Next up some burnout videos.
Re: FULL SPOOL
Posted: Mon Dec 04, 2023 11:11 pm
by Caveman49
What Boss said 👆
Re: FULL SPOOL
Posted: Tue Dec 05, 2023 9:44 am
by fryedaddy
i thought of an easy way to torque the ring gear bolts to the spool without putting it in a vice or trying to hold it with a screwdriver,etc. i laid my wheel on its side on the floor and put a axle standing up with the studs in the wheel holes and drop the spool on top of the axle,all the way down on the splines. it ends up about waist high,holds good while tightening bolts without damaging anything
Re: FULL SPOOL
Posted: Tue Dec 19, 2023 1:42 pm
by fryedaddy
i got my center section together,axles in.almost ready to try,but it just snowed and its below freezing so maybe one day next week if it warms up. i have 3 things to test at one time. nitrous,spool and parachute. i guess i will launch it, run it through the 1/4 or 1/8 and pull the chute all in one run.first time for all three. i will film it when i do.
Re: FULL SPOOL
Posted: Wed Jan 10, 2024 11:12 am
by fryedaddy
i finished up on the spool install.i took it around the block and out the road a few miles.i could feel the resistance when i turned,but it drove great when going straight. i got back home and thought i would double check everything.i had to snug up my center section bolts a little,but it was my fault i did not torque to specs the first time
Re: FULL SPOOL
Posted: Sat Jan 27, 2024 6:17 am
by saSSoman8810
I ended up twisting 31 spline yukon axles with a spool and a 331 windsor in my 65 wagon and that was on a SEGA legal 7 inch slick.
Went with 33 spline setup and new spool. If your car hooks and you are on slicks with a stick shift you will find the weak link.
