Page 1 of 2
T5 transmission questions
Posted: Tue Jun 06, 2017 5:58 pm
by ArkansasComet
I was wondering if some of you more knowledgeable folks could help me out with some transmission info. My initial plan for my 1965 202 was to use a C4 with a manual valve body since it was originally an auto car & I don't really want to go through the hassle of converting to a manual transmission. I am planning on using a 331 stroker for the motor. I don't plan on doing any serious racing in the car, I mostly want a fun street car that I may race occasionally. Today I had a coworker tell me he is selling a T5 transmission & it got me thinking. How hard is it to convert a Comet that was originally an automatic to run a T5? Here is a link to the transmission my coworker is selling, is this a good trans & price?
https://inlandempire.craigslist.org/pts/6064694027.html
Thanks for any input!
Re: T5 transmission questions
Posted: Tue Jun 06, 2017 8:45 pm
by redhotcomet
I'd say he's a little bit high but not too bad. Be aware that 94 and up had a longer input shaft that the earlier ones. By about 5/8" I believe. I don't think thats much of an issue, but you have to use the correct bellhousing or swap to the early short shaft and use matching bellhousing. There is lots of info out there on t5 swap into classic mustangs, pretty much the same for comets. Its not a hard swap. You'll have to decide what clutch actuation style you want - mechanical/z-bar, hydraulic, or cable. I went hydraulic with an external slave for fitment reasons. Internal slaves/hydraulic throwout bearings are also doable, but if your slave ever fails you have to drop the transmission since it rides on the input shaft. There is a floor brace that will have to be cut where the shifter comes through, and many people have cut it without any structural problems. If you have a bench seat shifter placement might be a problem. To solve that you can swap on a chevy s-10 tail shaft housing. But then you have issues with speedo drive and things. Lots of info out there if you google. I highly recommend the swap though, its one of the best things I've done to my car. Wish I had done it years ago.
Posted: Tue Jun 06, 2017 9:48 pm
by Loner
Little high on the price for California.About all you can get is pick-n-pull prices out here for them.
Guys run them a lot on the dirt roundy round here. Most hold up some don't. The ones I have run with the stock shifter felt very mushy. Put a after market one on,night and day difference.
Good luck
Posted: Tue Jun 06, 2017 11:42 pm
by ArkansasComet
Thanks for the detailed info. guys! I'll be in CA next week so I was trying to decide if I should grab this while I'm there. I think I'll pass on it & do more research. I appreciate the responses!
Posted: Wed Jun 07, 2017 12:20 pm
by Jims65cyclone
Here's some info that may be useful in your search:
http://www.britishv8.org/articles/borg- ... d-tags.htm
http://www.fordmuscle.com/archives/2000 ... /index.php
http://www.cometcentral.com/forum/viewt ... =4&t=14391
I'm planning to do the same thing. If you do go through with it, be sure and post EVERYTHING on your build thread...with pics...so I'll know what to do.
Posted: Wed Jun 07, 2017 12:37 pm
by ArkansasComet
Thanks for the info. Jim! I'll definitely keep you guys updated on what I do in my build thread!
Posted: Wed Jun 07, 2017 1:06 pm
by Rocket989
I'm stuffing one in & finally decided on the hydraulic (external slave) clutch route due to header fitment. The '94-'95's actually work better w/ a cable clutch since the fork opening (hence cable) is clocked lower; this allows for better header clearance. As RedHot pointed out, gotta use the right bell.
Posted: Wed Jun 07, 2017 7:15 pm
by albert
I used the cable clutch setup on my T5 conversion and it has a stiff pedal. Now that I am older and have arthritis in my left leg I wish I had the hydraulic set up which is much easier on the leg. Will probably change this out soon.
Posted: Wed Jun 07, 2017 7:40 pm
by ArkansasComet
Are you guys using an original clutch pedal assembly or is there an aftermarket one that fits?
Posted: Wed Jun 07, 2017 8:33 pm
by redhotcomet
ArkansasComet wrote:Are you guys using an original clutch pedal assembly or is there an aftermarket one that fits?
I used an original pedal assembly. I'm not aware of any aftermarket setup, but that doesn't mean there isn't one. Modern Driveline has a kit you can buy, but its a little on the pricey side in my opinion. And a little more complicated than it needs to be.
http://transmission.moderndriveline.com ... 25p522.htm
Posted: Wed Jun 07, 2017 10:27 pm
I looked for a while for my T-5 until I found what I was looking for, cheap
I think most likely you can find a inexpensive one around this part of the country if you end up going that route and a pedal assembly has to be easy enough to find salvage someplace.
Posted: Wed Jun 07, 2017 11:26 pm
by tomb22
I bought one on ebay for $500.00 to replace the one I trashed in my 95 Mustang. Seems to be working fine so far.
Posted: Thu Jun 08, 2017 12:24 pm
by ArkansasComet
I wonder if something like this would work better (and be cheaper) than trying to source an original clutch pedal assembly & converting it to hydraulic? I am not worried about it looking original since my car won't be very original.
http://www.speedwaymotors.com/Speedway- ... 57508.html
Posted: Thu Jun 08, 2017 7:56 pm
by redhotcomet
That looks like it should work, but you'll probably want a push type slave cylinder, not a pull type.
Posted: Wed Oct 27, 2021 6:59 pm
by miley
can i ask how you connecting clutch cable to the clutch pedal on a 65 comet
