Filter in gearbox?
Posted: Wed Aug 16, 2017 1:23 am
by HarryK
I have a mercomatic in my 64 caliente. The oil needs to be changed. I wonder if somebody knows if there is a filter inside the gearbox that needs to be changed and where in that case I can get a hold on one. Is the mercomatic the same gearbox as ford cruiseomatic?
Re: Filter in gearbox?
Posted: Wed Aug 16, 2017 8:28 am
by bmmaurer
Mercomatic, Yes there is a filter. NOT replaceable, just clean the old one with brake cleaner or gas.
IF it's a C4...
http://www.ebay.com/itm/NEW-Genuine-For ... 1341110446
Comet Bruce
Posted: Wed Aug 16, 2017 3:55 pm
by HarryK
Thanks i will do that when i change oil. Is the filter easy to spot when you dismanteled the oilpan?
Posted: Wed Aug 16, 2017 6:29 pm
by Comechero65
If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
Posted: Wed Aug 16, 2017 7:32 pm
by bmmaurer
Comechero65 wrote:If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
Replaceable but pretty much unobtainable...
Bruce
Posted: Wed Aug 16, 2017 7:33 pm
by bmmaurer
HarryK wrote:Thanks i will do that when i change oil. Is the filter easy to spot when you dismanteled the oilpan?
Yes, right there.
Bruce
Posted: Wed Aug 16, 2017 9:38 pm
by Comechero65
bmmaurer wrote:Comechero65 wrote:If that trans is the same as the 2 speed used in falcons it would appear to have a filter which appears to bolt in so should be replacable.
Bruce
So obviously replacements are not available. In that case the best you can do is just try to clean it and reinstall.
Posted: Wed Aug 16, 2017 10:10 pm
what ever you clean it with....blow it and let air dry as long as you feel safe ...jmo.....pop
Posted: Thu Aug 17, 2017 1:03 am
by HarryK
Thanks for the help guys. How much oil do I need to buy before doing the oil change?
