Scott Drake - big bearing spindles & brakeconversion?
iglooman
Post by iglooman »
Hello team.
I'm upgrading my 65 caliente to V8 stuff and since the Scott Drake big bearing stuff is only a little more I figured I would go with that.
But so far have no confirmation the following will all work (below). I assume they will since 65/66 falcon/ranchero/mustang steering stuff will all fit, minus center link of course.
1965 - 1969 Mustang Big Bearing Front Disc Brake Kit (DBC-A120-BB-DS)
Big Bearing Forged Front Spindle, Passenger Side, 64-70 Mustangs (C5ZZ-3105-HD)
(with outer tie rod upgrade)
Big Bearing Forged Front Spindle, Driver Side, 64-70 Mustangs (C5ZZ-3106-HD)
Thoughts? Feedback?
thank you all!
gary
Re: Scott Drake - big bearing spindles & brakeconversion?
Looks like it’ll all bolt up ok. Good luck and post an update
I have a pair of new old stock disc brake spindles if your interested.
C8OA 3107-B
C8OA 3108-C
iglooman
Post by iglooman »
Mon Jun 05, 2023 8:24 am
C8OA 3107-B
C8OA 3108-C
Thanks Jim.
I decided to go with a 71-73 used set and see how that works out.
Are the C80A big bearing?
gary
iglooman wrote:
Mon Jun 12, 2023 9:51 am
C8OA 3107-B
C8OA 3108-C
Thanks Jim.
gary
I do not know what the bearing size would be, the spindles are packed in a box somewhere on my parts rack.
I believe these are ‘68-69 Mustang disc brake units. I am sure they would fit Comet control arms, I used ‘70 Boss 302 spindles on my Cyclone, only difference was the depth of the outer tie rod taper.
