Holley 1 Barrel
Holley 1 Barrel
Hello All, I was doing some research on the carb on my '62 144, as it didn't look anything like the ones in the shop manual. Turns out it is a Holley 1940, which they apparently provided to Ford as a service replacement. It seems a bit more complex than your standard Autolite 1100, but I'm very happy with its performance. It has what I guess is a vacuum choke pull-off, which could easily be mistaken for an accelerator pump. I don't see the actual pump though, as I think it's internal. If anyone has any experience with these, I'd be glad to hear from you.
Re: Holley 1 Barrel
A HOLLEY model 1920 1bbl is also a superb carb to use.
