My '66 Caliente 2-dr.'s rear shelf; (directly behind the rear seat under the rear window), has really faded. While the car is undergoing a restoration at the body shop, the mgr. there told me he couldn't find a source for a replacement.
Does anyone have any ideas where a replacement could be found? The compelling reason to replace the deck is one of the previous owners, (who had a moment of pure revelation), decided to install a "3rd Stoplight" by cutting out a hole in that deck! Grumble, grumble. Obviously, that 3rd light wasn't standard until a few years later.
What is the material the rear deck/shelf is made of? It seems to have the look/texture of cardboard or something similar. Can it be refinished, if so, with what: paint?
Rear Shelf Replacement or Rehab?
My wife says I only have 2 faults. I don't listen...and something else
Re: Rear Shelf Replacement or Rehab?
I would guess one for a fairlane would work but it's a guess. Mine was wrapped in black vinyl or pleather by the P.O..
mine was like a fiber brd and I painted it,,,it's holding up good so far...but my comet seldom sits very long in the bright sun very long at a time...that helps it to survive.........pop
Unless it is broken,most people refinish it!! ROY.
Real Racecars have 3 pedals
My rear shelf is made of fiberboard like pop's. I believe I bought a 4x8 sheet at lowe's or Home Depot.
You can buy 1/8" hard board at Lowe's or Home Depot. Use your old shelf as a pattern and trace it onto the hard board and cut it out with a jigsaw. If you paint it, you'll need to seal it first with Kilz, or you could cover it with vinyl to match your interior.
