Help Identify Ring Terminal
Posted: Mon Mar 26, 2018 3:39 pm
by GeneB
I have these two terminals on my 63 Comet. Were on car when I got it last fall. Car has 302 engine with alternator. One terminal is on wire to alternator, the other is on hot wire to horn relay.
Do these terminals have some kind of component (diode, fuse) inside them or just the body of the terminal. 0 ohms between terminals at both ends of wires
Big Terminal 1 small.jpg (34.29 KiB) Viewed 1146 times
Big Terminal 3 small.jpg (55.23 KiB) Viewed 1146 times
Re: Help Identify Ring Terminal
Posted: Tue Mar 27, 2018 8:30 am
by redhotcomet
Looks to me like thats the original charging circuit wire. It would have come from the generator and run up to the ammeter in the dash and then back to the starter solenoid. When the alternator was install they likely just ran a new heavier wire straight to the battery.
Posted: Tue Mar 27, 2018 10:21 am
by GeneB
That makes sense. Both wires look old.
I found this picture of 1965 Mustang generator wiring
Must be just the way they covered the terminal back then
