crites hood
navychief
crites hood
Post by navychief »
I noticed yesterday while going about 65 /70 mph I noticed my hood rising up some, I have a cut out in the plenum for a 10" dia air cleaner that fits up nice into the plenum,, should I drill some holes in the rear of the plenum to relieve more air pressure at high speeds , thanks
Re: crites hood
Some pics how I did mine in this thread.
viewtopic.php?f=9&t=15279
if you dont have hood springs & use a hood prop your old hinges probably have slack in them like mine ,the slack is what lets it rise up. you could get a new set of hinges if you dont want it rising up but my thinking was it may be letting out air when it does. After Roy mentioned his hood ''balooning'' apart I decided to drill holes in the plentium.
navychief
Re: crites hood
Post by navychief »
If anyone has had this problem and drilled holes in the plenum ,let me know how many and what size holes ,thank you.
Re: crites hood
navychief wrote:If anyone has had this problem and drilled holes in the plenum ,let me know how many and what size holes ,thank you.
I replied to your PM with a PM. check your messages.
