4 Speed Tunnel Hump
4 Speed Tunnel Hump
Gettin ready to cut the whole for the Toploader. I went to trace it out and when i moved it the dust had already done it for me.
Re: 4 Speed Tunnel Hump
JIM,it appears the good LORD,lent you a helping hand....when I cut the hole in mine ,I cut it just barely big e'nuff for the shifter,,,I did not want no more hole then needed,,good luck,your doing good stuff,,keep it up pop
Thanks pop. Don't you need the bigger hole to clear the linkage? Jim
Hey Jim when I cut the shifter hole in my 65 I did just that. Traced it and cut 1 inch inside the mark. It's gonna come damn close to the trans crossmember so look out!
On mine even with the big hole the shifter is a tight fit just about everywhere.
Also instead of screwing it down I used small bolts with nuts.
Good luck!
Good luck!
I saw a picture of JOE'S hole (that don't sound to KOSHER,does it)anyway the hole I cut for mine is not as big as JOE's,I have a stock shifter....pop
hey jim , looks like ur doing an awsome job on that car. looking good keep it up
Thanks pro, where have you been? How's your car coming along? Are you going to Carlisle this year? Jim
popscomet wrote:I saw a picture of JOE'S hole (that don't sound to KOSHER,does it)....pop
hey jim spent most uv winter sick, didnt have it in me to get in the shop. whether is finally breaking got urge to work on it again hope to post pics soon...
