62 Cometman
62 Cometman
Postby 62Cometman » Wed Oct 04, 2017 9:50 am
Hey guys, ive been watching and reading and learning for a while and finally decided to join. I have a 1962 Comet, Corinthian white, with an aqua interior that i reupholstered, it has a 170 six that i rebuilt this last winter, more of a freshining up, ball honed the clyinders new bearings and rings, NOS metal shim head gasket, relapped and ground valves, shimmed springs, head machined .060 inch and all new gaskets, speed daddy dual outlet header, full 2 inch exhaust with thrush glasspacks that dumps right in front of the passenger rear wheel. 2.77 tranny rebuilt still using same old syncros cause no one cars to make a new set, rebuilt drive shaft and 7.25 rear with 3.50 ratio, american racing outlaw II wheels with BF Goodrigh Radial T/A rubber, scarebird 4 lugs disc brake set up on the front. Custom made adjustable monte carlo bar, currently in the process of making boxed upper and lower control arms and some "nicer" tie rod adjuster sleeves using some swedge tubes and lock nuts, after a complete front suspension rehaul i plan on going over to the rear and doing the same then installing both front and rear sway bars 1 1/8 inch front and 7/8 rear then future plans are a turbo 200 with a T-5 and 8 inch rear. :twisted:
62Cometman
Re: 62 Cometman
Postby poboyjo65 » Wed Oct 04, 2017 12:02 pm
Welcome on! :D love to see it! :P
347, 4sp, 9''
JOHNO
Re: 62 Cometman
Postby loman » Wed Oct 04, 2017 7:01 pm
I'm glad you decided to join. Welcome aboard. I don't know if it is just me, but it seems like there has been more and more 62 and 63's starting to show up. That's great! If you get the chance load some pictures, I'm sure everyone would like to see your ride.
loman
Re: 62 Cometman
Postby Jims65cyclone » Wed Oct 04, 2017 9:27 pm
Welcome aboard! Sounds like a neat ride. Let's see some pics.
15x7x3.75BS TTII's all around
Re: 62 Cometman
Postby popscomet » Thu Oct 05, 2017 1:29 am
ALL sounds mighty spiffy to ol pop,,,welcome and good luck pop
Re: 62 Cometman
Postby 62Cometman » Thu Oct 05, 2017 9:26 am
62Cometman
Re: 62 Cometman
Postby popscomet » Thu Oct 05, 2017 10:11 am
nice looking comet,,,pop
Re: 62 Cometman
Postby Santa's Comet » Thu Oct 05, 2017 6:28 pm
Very Nice Ride!!! I'll bet it turns heads!
NP Dave
Santa's Comet
Re: 62 Cometman
Postby 62Cometman » Fri Oct 06, 2017 8:27 am
Thanks! I know i got a long way to go still in some areas but id like to think its a decent driver
62Cometman
Re: 62 Cometman
Postby poboyjo65 » Fri Oct 06, 2017 9:46 am
Looks great! :D only thing, it puzzles me how it has the same shaped paint chipped on both sides of lower fenders. :? But I'd say it is a few notches above a decent driver. :D
347, 4sp, 9''
JOHNO
Re: 62 Cometman
Postby 62Cometman » Fri Oct 06, 2017 2:42 pm
Those arent paint chips theyre rust holes :oops: luckily i have another set of fenders waiting to be reworked an mounted, which is a shame because the fenders on the car are neigh on perfect other than those rust holes
62Cometman
Return to Introduce Yourself
