Boat
Re: Boat
Postby Comechero65 » Fri Oct 14, 2016 12:27 pm
Ford changed the firing order to reduce the load on the front rod journal.
Comechero65
Re: Boat
Postby popscomet » Fri Oct 14, 2016 1:40 pm
Comechero65 wrote:Ford changed the firing order to reduce the load on the front rod journal.
.........10-4............ :D
Re: Boat
Postby poboyjo65 » Fri Oct 14, 2016 1:48 pm
popscomet wrote:
Lip Ripper wrote:Firing order depends on the cam. A lot of performance cam's for 289/302's use the 351W firing order.
The thumper cam from comp that I'm using has a 351w firing order.
do you know why??
it fits a 351w but can be used in a 302 also. Is that what you meant Pop?
347, 4sp, 9''
JOHNO
Re: Boat
Postby popscomet » Fri Oct 14, 2016 4:48 pm
yes and no.......it was mainly to lighten the load on the crank,,,,,,
Re: Boat
Postby popscomet » Fri Oct 14, 2016 4:49 pm
popscomet wrote:yes and no.......it was mainly to lighten the load on the crank,,,,,,
let me resay that ,,the W CAM CAN BE PUT IN A 302 OR A 289
Re: Boat
Postby poboyjo65 » Fri Oct 14, 2016 5:48 pm
I've heard all that about the crank flex but what I'm saying is in my case it was so that comp cam could save money by selling same cam for both engines. :wink:
347, 4sp, 9''
JOHNO
Re: Boat
Postby popscomet » Fri Oct 14, 2016 6:00 pm
poboyjo65 wrote:I've heard all that about the crank flex but what I'm saying is in my case it was so that comp cam could save money by selling same cam for both engines. :wink:
THE WAY I SEE IT ,IF it wasn't for lighten the load on the throw,the CAM MAKERS could have left them alone...besides I read many yrs ago why ford did it.......it might be a money thing but I really don't know......think of the load when 1 and 5 fire almost together
Re: Boat
Postby Comechero65 » Fri Oct 14, 2016 6:37 pm
What I read was cyl 1 & 5 were firing so close together it was speeding up failures on that journal or accelerated wear was why they changed it. That's all I know.
Comechero65
Re: Boat
Postby CALIFORNIA CALIENTE » Fri Oct 14, 2016 7:14 pm
I have been racing SBFs for way too long,NEVER had a crank or bearing failure with 15426378 FO!! When I built my first 351W,used a COMPCAMS cam that was ground to the early FO,365,000 miles later,never had a crank or bearing issue.My 418" Windsor has a Crane Cam ground with the early FO,NO issues!! I heard FoMoCo did it for smog reasons,NO proof though!!I do have cams in the wagon and the Cougar that are ground with late FO,they all seem to run fine!!! JMO , ROY.
Real Racecars have 3 pedals
CALIFORNIA CALIENTE
Re: Boat
Postby popscomet » Fri Oct 14, 2016 7:44 pm
THAT ALSO GOES FOR POP,all my stuff runs plenty good always have ,,fo has never been in play,,it is what it is ...of course POP don't have extra high hp ,but they all run good and mostly have for several yrs
Previous
