Update: I think the issue has been found. New guy at the parts house gave me the wrong block mounts
Here's a little info for anyone else in the future searching.
Concerning block mounts: Turns out that there are different height mounts. There's a lot of good info about the years and style changes but I really was digging when I found the following information out. Hardtop mounts are "short" and the convertible mounts are "long".
From vintage-mustang.com "There is one design for small blocks for fixed roof cars, one for 'verts (and big blocks). The holes through the frame bracket are drilled differently, changing the position of the through hole for the bolt that holds the insulators to the frame bracket, thus the different insulators 'Verts use the "long style," hardtops (which includes sportsroofs) use the short style."
67 frame mount next to 68 frame mount:
From mercury-cougar.net: "On a 67 small block and a 67 big block they used the same frame brackets. There was only one left style and one right style for all 67 Mustang and Cougars with a V8. In 68 they changed the brackets on a small block but continued using the same one on a big block but on convertibles (Mustang obviously) with a small block they continued using the 67 small block insulators and the big block style brackets. This is what Ford did through 1970. All 68-70 closed cars with 289, 302, 351W or 351C used one style of frame bracket and all 67 289 and 67-70 390, 428 and 67-70 289, 302, 351W, 351C, 390, and 428 convertibles used the other style frame bracket. This makes it very difficult because the insulator used on the small block convertible and 67 289 is special and very hard to get. When you go to most places the parts book show the same insulator for 66-70 Mustang and Cougar but this information is wrong and convertible and 67 289 owners know this all too well. Originally Ford sold two different small block insulators. There was a C7ZZ-6038-E (plus additional numbers for revisions like the D0ZZ listed below) for 67 289 and all 67-70 small block convertibles (including 351C) and a C8ZZ-6038-A (plus additional numbers for revisions like the D0OZ number below) for all 68-70 small block closed cars. Just to make matters worse Ford was constantly changing these numbers and in the 1975 MPC it shows that 67's and convertibles with small blocks used a D0ZZ-6038-B mount and 68-70 closed cars with a small block used a D0OZ-6038-G mount."
Looking around the parts sites confirms this information.
Tall Style states...
Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
Motor Mount Insulator, Tall Style, for:
-11/1/65-1968 289 Mustang Convertible
-1968-1971 302 Mustang & Cougar all bodystyles except 1971 Convertible
-1969-1972 351W Mustang & Cougar Convertible
-1970-1972 351C Mustang & Cougar Convertible
Short Style States...
Motor Mount Insulator, Short Style, for 1965-10/31/1965 289 Hardtop, 1968-1971 302, & 1969-1972 351C & 351W Hardtop.
So... with my new found knowledge I'm going to order up a set of clam shell mounts from Prothane. Will update this thread when they arrive.
