Tank was $140 gas $20, they had a smaller tank but thought this one was better, they said I could trade up if I wanted a bigger tank for the difference in cost.poboyjo65 wrote:how much did that small tank cost? tank & gas cost.
My gas line is too small to attach to the fitting, hopefully tomorrow I can resolve that. How much pressure do I give the gas?poboyjo65 wrote:why don't you use the gas now that you've got it?
Those plates 3/16" and I was afraid I would burn through more than weld and I figured I would have better luck plug welding them and they would be a little neater in the trunk.poboyjo65 wrote:why didnt you just weld the tubs up on top, instead of those plug welds?
Also I forgot to mention that the 2 lb. spool and the 10 lb. spool cost about the same price so I am hoping from this point forward it will be cheaper with the gas.
