Built my air ride control box today. It is built from scraps of the frame from shed (8x2" C-channel, galvanized) the front is a piece of 16 gauge from the steering mod I did earlier, I cut the rectangular holes with a Dremel tool that had tiny little cut-off wheels mounted in it, it took about 10 of them.
The spots on the front were because I was priming it outside and it started to rain
So the rectangular holes are for the paddle valves and the two round holes are for the compressor switch (to turn it off manually if needed) and the other is a momentary (or push and hold) button to work the air tank drain, I wish I would have got the round holes straight across
I sprayed truck bed liner on the front and test fit everything ( the paddles are only just barely pushed it because I need to have them out for now)
I spaced the paddle valves so they were in pairs, my thoughts are a front pair and a rear pair.
I have more holes to drill for air lines and wires, etc. so I might get that done tomorrow. This will mount between the front seats.
