Rocket's Comet Build
Posted: Tue May 17, 2016 10:47 am
So the time has just about come for "Phase 1"!! I took next week off and plan (hope?!?) to get the following stuff done:
-9" rear with disc brakes, new leaf springs (for Falcon Ranchero - stiffer than std. Comet stuff)
-ALL the front suspension and steering…UCA's, LCA's, coils, perches, QS idler/ pitman arms, steering box, inner/ outer tie rods, center link
-CSRP front disc brakes with new spindles, new shocks at all 4-corners
-Export brace, engine brace, Crites subframe connectors (already have the MC bar), 1" front sway bar
Basically, everything under the car is getting replaced!! I'll need to wait until the springs settle to install the Traction Masters and may or may not go with a rear sway bar, if I can find a 1/2" or 5/8" part.
Phase 2 will be getting the 260/ T10 swapped out for a 302/ T5 (have most of the parts and will start building that stuff soon - I've been working on it in parallel), then interior, and finally body/ paint. The latter two are likely to take some time but NBD!! My plan has been to make it safe, handle and stop well, then add POWER!!
We should get a pool going on whether I can finish in a week or not!
I'll start getting pics up and will toss up plenty as it progresses. I've spent the last two years getting it running right, fixing A LOT of wiring, prepping the above parts for install, and saving the loot to buy all the stuff. I gotta say…add 50% to whatever ya estimate…it's the little stuff that'll kill ya!! I'm hoping to limit to TWO trips to parts/ hardware store; we'll see!
Current steering:
Current under car rear view:
Under car:
Current interior:
Engine compartment when I bought it:
Engine compartment now:
I'll also get plenty of pics of all the shiny new parts, just for Joe…although who doesn't like shiny new parts?!? From the Ranger master cylinder to the Koni's!!
Current steering:
Under car:
Current interior:
