Tire size Torq Thrust D 65 Comet
hello guys!
can someone tell me what tire size i can run on my 65 comet with torq thrust d rims 7x15?
i thought about 225/60 15... will they fit without any problems?
many thanks tom from austria
Re: Tire size Torq Thrust D 65 Comet
kayos;not without narrowing the rear end.I had 225X70X15 on mine and they rubbed even with the lip rolled. ROY.
Well I know 215/70/15s w/15X7 TTO wheels rub in the front fenders when my chassis bottoms on some bumps...rears do fine. Next time I might try 205s or 65 series tires on the fronts.
I have 21570r14 front on 14x6 torq t d whl ,never no problems rear,22570r14 will bearly rub in ahard lean or if have a lot of wheight in trunk or LARGE people in rear seat.....but nothing hard nuff to even mar the tire,,it's mostly on dr. side........Hope this info helps!! FRED if you read this,,,,, got a new camra today. PICs are coming....just have to learn how to use it and get them on here! DON't give up on me, yet. by the way my comet is a 64!! thank-you pop!
Where are those guys from that say " I'll believe it when I see it"?
Ithink they from half way between the A and the T. When it comes to computs and camras and such...I'm as good as a mud fence, in FLOOD ZONE!!pop..don't give up....pop
Hi , I installed a set of 15" Torquies with 225/15/65 tires on all four corners and they are PERFECT! No rub, killer stance and an agressive look! Just remember there is precious little room in those wheel wells so BE CAREFUL with sizing on both wheels and tires. I might add too to consider back spacing. sounds like you are building a nice ride. GOOD LUCK!!
Kind Regards, TOM
Kind Regards, TOM
Hey Tom do you have pics of your car with that wheel/tire combo?thos25 wrote:Hi , I installed a set of 15" Torquies with 225/15/65 tires on all four corners and they are PERFECT! No rub, killer stance and an agressive look! Just remember there is precious little room in those wheel wells so BE CAREFUL with sizing on both wheels and tires. I might add too to consider back spacing. sounds like you are building a nice ride. GOOD LUCK!!
Kind Regards, TOM
I may go to that size tire to fix my rubbing issue.
- Comet Central Member
I tried 215s on 15s on my caliente and they rubbed, I switched to 195s, and they worked out nice,Its for sale at classic cars west if you want to se pics, My HIPO has 10" cheaters, and with air shocks and 67 lbs, they work out well.
Hope this helps
Hope this helps
Hi Joe, I do have pics of my car. I am not sure if I can send them via this site. If you shoot me an e- mail I am sure my son can send you several. Kind Regards, TOM tcthwaite@msn.com
okay... now i know 225/60 15 is too much in front...
i have to change the rubber to 205/60 15...
