How has everyone set up their carb and filter to work with the Crites ram air hood? pics would be great. The air plenum isnt wide enough for anything but a 10 inch round filter.
I have an Edelbrock performer intake so do I need to raise up the filter or get a much taller filter or fabricate a pan with foam rubber seal ? Just looking for ideas. I see how Roy did his from the Car Craft pics. Thanks,
Don
ram air questions
ram air questions
'65 Cyclone, 5.0, Gt40X heads, HO cam, Edelbrock 600, T5, 9" 3.70 gears, MII susp.
Re: ram air questions
Don;those hoods were designed for the twin 4 barrel,427s with the long.narrow air box.About all you can do is a small air cleaner,sealed off similar to mine.I used a Moroso universal kit with a K&N filter with their filtered lid.It will get cooler air to your carb even with out a seal. ROY.
Real Racecars have 3 pedals
Roy, Thanks. After I posted the question I had found the Moroso air pan in a Jegs catalog. I guess I'll get one of those.
Don
Don
