Hole in the Floor
Hole in the Floor
Postby Rocket989 » Wed Aug 16, 2017 10:04 am
I have to fix the (lousy!!) hole the PO cut out for the old T10 linkage & hump. I was just gonna weld-in a piece of appropriate gauge sheetmetal but any suggestions on the best way would be appreciated! :D :D
Rocket989
Re: Hole in the Floor
Postby poboyjo65 » Wed Aug 16, 2017 10:52 am
first thing I would do is recut the hole to a straight cut square hole . it looks like he used a can opener :lol: . But since it dont show I would just lap a sheet over it & weld it. I wouldn't butt weld it , (if it were my car.) If it was a really nice car I might. I use weld thru primer on lapped welds, to coat the surfaces that get covered up. or if I had any body panel adhesive on hand I might just glue it, which would seam seal it all at the same time. but @ $50 something a tube I would not pay that much to patch that hole.
347, 4sp, 9''
JOHNO
Postby Lip Ripper » Wed Aug 16, 2017 12:03 pm
What he said. ^^^ I've become a fan of the punch and flange tool as well.
Lip Ripper
Postby comethead » Wed Aug 16, 2017 2:38 pm
What's wrong with that hole!? Looks ok. :mrgreen:
1965 Caliente HT
289/4 speed
Postby Comechero65 » Wed Aug 16, 2017 4:35 pm
I think I would do as John suggests and recut the hole more square, then use a flanging tool on the edge then fab a cover plate to just fit in there. could be sealed and screwed in place. then it would be removable should a person ever need access.
Comechero65
Postby Rocket989 » Wed Aug 16, 2017 6:17 pm
John - you sayin' my Comet ain't really nice?? Haha! :D :D Nah, I agree...I'm gonna clean up the hole for sure...it was another hang the head moment when I took the improvised hump off. FFS!!
Stacey - what tool you talking about??
Joe - Yah, like the firkin Flintstones!!! :lol: :lol: :lol:
Ron - Yeah...have a flanging tool...may try that since I'm definitely lapping it!!
Rocket989
Postby vicegrip » Thu Aug 17, 2017 5:55 am
What? That hole is clean compared to some OEM holes I've dealt with....cut with a TORCH,not even close to conforming to any type of pattern. Just kidding,of course,but if it were me,I would make a pattern of the hole out of beer box cardboard to make a patch and butt weld it in,grind it down,make it look good.
Can't help myself....
vicegrip
Postby lavron » Thu Aug 17, 2017 6:38 am
vicegrip wrote: if it were me,I would make a pattern of the hole out of beer box cardboard to make a patch
Does it have to be a beer box? :roll: :lol:
Postby Rocket989 » Thu Aug 17, 2017 7:53 am
Hehehe - I've got enough empty Natty boxes to fab an entire floorboard..with a steady supply of replacements always available! :lol: :lol: :D :mrgreen: :mrgreen: :o
Rocket989
Postby Lip Ripper » Thu Aug 17, 2017 8:38 am
This one.
https://www.harborfreight.com/air-punch ... -1110.html
Eastwood has one for $60 and I'm sure it's better. I bought the above cheapie. It worked, then it didn't. Took it back and got it replaced. That one still works.
Lip Ripper
Postby Rocket989 » Thu Aug 17, 2017 9:11 am
Ahh, ok! I couldn't picture what you were talking about!
Rocket989
Postby Lip Ripper » Thu Aug 17, 2017 11:13 am
So, you can flange one piece, punch holes in the other and use that hole to weld the piece in.
Lip Ripper
Postby Comechero65 » Thu Aug 17, 2017 11:18 am
I have the same flanging tool that Lip Ripper has from HF. Have never used it other than to test it. The need has never come up. Should work though.
Comechero65
Postby StPro » Mon Aug 21, 2017 3:21 pm
That is an ugly hole. There is no wrong way to fix it my preference would be to build a patch to go Over it but I would not use square corners I would use round corners
Projects
65 Comet 421Stroker
70 Torino GT
StPro
Return to Body Shop
