So I popped one of drip rail moldings off today, I was nervous about bending them (the one came off fine) but they need to come off so I can replace the seam sealer in the drip rail and they could use a few small dents tapped back out.
What is the best way to remove the old dried out seam sealer?
I just drove it ,,,been sitin for 3wks had to pick it's prime up but then it just bust's off and as long as I start it every couple of days it always starts as soon as the starter kicks in ,,,,more then a few days of not starting it ,,,I have to crank on it,,,been that way ever since I started using EDELBROCK carbs,infact everything I ever owned has been that way with those carbs....might help if I would add a choke cable as I have the chokes in op...ON WELL !!! .......POP :) :wink:
Mine's the same way, and I've got an Edelbrock carb. Once it cranks, it'll crank again on the first turn for 3 or 4 days. If it sits for a week or so, it takes some cranking to fire off. I've got an electric choke kit on the shelf (birthday present from my son-in-law), so hopefully that will help when I get it on. He also gave me a 1" spacer that I'll install at the same time. Had to sit idling for about 5 minutes with a hot engine waiting to get gas after the hurricane, then shut it off when I got to the pump. After getting gas, it took some cranking to get it restarted. Hopefully, the spacer will help that situation.
ye, might be wrong...as OL POP ain;t the brightest light in the cluster....it will help with the spacer...
lavron wrote:So I popped one of drip rail moldings off today, I was nervous about bending them (the one came off fine) but they need to come off so I can replace the seam sealer in the drip rail and they could use a few small dents tapped back out.
I took an old screw driver that was smaller than the bottom of the rail and gentle used it as a chisel Mike. It worked good. Then installed that 3M epoxy metal adhesive.
tomb22 wrote:I took an old screw driver that was smaller than the bottom of the rail and gentle used it as a chisel Mike. It worked good. Then installed that 3M epoxy metal adhesive.
Yes that is what I figured would have to happen, some of it I popped out by hand (there is still more loose in there) and some of it is still firmly attached, I guess it would be best to try and remove all the 50 year old sealer and replace it?
StPro
Post by StPro »
I ordered a replacement cowl panel today. One less piece to patch.
Projects
65 Comet 421Stroker
70 Torino GT
StPro wrote:I ordered a replacement cowl panel today. One less piece to patch.
which one did you get ? the closed in one or the one with slotted vents? tell us how it fits when you get to doing it.
StPro
Post by StPro »
I do believe the one with slotted vents. I didn't know there was a closed one. My cowl has three of the bars on the vents with hole. I did think about cutting them out but then i would have to remove the same on both sides to stay symmetrical. When I taped it up it looked weird. Since I was replacing the firewall and the bottom of the air box this will make it easier.
Projects
65 Comet 421Stroker
70 Torino GT
I dont know if autokrafters has them but dynacorn is the manufacturer of both. here is a pic of the ventless one;
http://restorationpartssource.com/store ... 5qEALw_wcB
appears cheaper too, though shipping could be worse.
StPro
Post by StPro »
poboyjo65 wrote:I dont know if autokrafters has them but dynacorn is the manufacturer of both. here is a pic of the ventless one;
That panel would mean you would not need to patch the one under it to keep it from leaking on your feet :D
Projects
65 Comet 421Stroker
70 Torino GT
Comechero65
Post by Comechero65 »
And without the louvres you'll no longer have a fresh air heater but if you open the inside pass side heater door you'll have recycled air. but you feet will sray dry.
StPro
Post by StPro »
Comechero65 wrote:And without the louvres you'll no longer have a fresh air heater but if you open the inside pass side heater door you'll have recycled air. but you feet will sray dry.
I have been to the track on hot days and having the vents working is a real plus.
Projects
65 Comet 421Stroker
70 Torino GT
Took it out for a few quick rides today. first time in 3 months. An Ac project snowballed into a bunch of other work that needed to be done before it all got buried beneath. But it was a beautiful fall day for a drive. But between washing off the dust & sweeping out the shop while the car wasn't in the way there wasn't much time left, but it felt good to grab some gears & feel that rearend twitch around :twisted:
Got my trim mounting clips/studs today and bolted the grill and hood trim fully, going to count this little project complete.
I had to touch up the grill where I scratched it the other day putting the trim (temporarily) on way too soon after I painted it, so while I had the flat black out I sprayed a little on the stuff behind the grill it made everything pretty much disappear. I will do a permanent job painting the core support after I repair/replace it.
Haven't picked my next mini project for the Comet yet but the weather is getting a bit cold to think about doing much more painting, I might take a stab at repairing my "new" steering wheel just for fun. :roll: and there is always motor stuff :P
