Wiring ideas for your car
Re: Wiring ideas for your car
Postby 62Cometman » Tue Dec 05, 2017 5:41 pm
Hey there i didnt see if you had decided anything on running wires into your doors, everyone was talking about how they dont like wire in loom designs and id generally say i agree but luckily someone thought of a intelligent alternative check out these door jam connections
https://www.amazon.com/Keep-Clean-16135 ... B003TVL5N8
they use a brass contact with a steel plate that makes connection for your door when they are closed and opens the connection when their open without having to bend wires, the down side obviously being that you cant control anything on the door with it open but they work really well, painless used to sell a simlar design that has since been discontinued for some unknown reason
62Cometman
Postby tomb22 » Tue Dec 05, 2017 10:55 pm
62Cometman wrote:Hey there i didnt see if you had decided anything on running wires into your doors, everyone was talking about how they dont like wire in loom designs and id generally say i agree but luckily someone thought of a intelligent alternative check out these door jam connections
Thanks for bringing these up Cometman. I saw these and thought about it, but I want to use the courtesy lights in the doors. I'm thinking of going with this.
http://www.ebay.com/itm/Electric-Life-W ... 1842561722 Lou gave me this link.
Postby Kingspeedy2 » Thu Dec 07, 2017 6:02 pm
As per most things there are pros and cons. MY American autowire update kit doesn't have firewall connector so I was wondering about alternative methods of passing the bulk of the wires from a new wiring harness from the fuse block through to the engine compartment.
you can have a Delphi gang connector or similar as what Tom22 shows earlier In this post which groups most of the wires into a neat package.Very similar to the OEM which would probably outlast me anyway
the cons with that style is you have a crimp connect on the wires on both sides of the connector and then you are relying on the contact between the connector itself.
It makes sense to avoid unnecessary connections if you can as that's were trouble lies. What other methods can be deployed for going through to the fire wall to keep the wire runs joint free yet neat with out having a bunch of individual grommets and or just a bunch of wires In a harness surrounded by silicone
EDIT ;I did find this site on line whch has a lot of clean looking grommet devices http://sealsit.com/product-category/grommet-seal/
Kingspeedy2
Postby Lou's Comet » Thu Dec 07, 2017 7:30 pm
Kingspeedy2 wrote:As per most things there are pros and cons. MY American autowire update kit doesn't have firewall connector so I was wondering about alternative methods of passing the bulk of the wires from a new wiring harness from the fuse block through to the engine compartment.
I am going to have individual grommets on mine. Ron Francis wiring kits also do not have a firewall connector, and they actually advise against it. Every crimp, connector, or contact can be a future problem. Plus I am using heavier gauge for some of the stuff. I don't want to run 12 gauge wire into a connector designed for 14-16 kwim?
On mine I will have 5 grommets, one for each side lights, parking lights and horn running inside of each fender. One for the wires going to engine, one for the positive going to starter and one for the negative going to block. Although I may combine the pos and neg into one grommet. If you put a covering over the wires and use a grommet to fit the covering I think it will still be a clean looking install.
Postby rjones35 » Fri Dec 08, 2017 2:37 pm
I'm a little late on this one, sorry..... wiring isn't my thing, so when I saw how jacked up the wiring on my 63 was when I got it, I knew it had to all be replaced. I wanted simple and good, and easy to I stall. I looked at a bunch and ended up with Centech. Really good to deal with. I sent him what I had, and he made one for my car. I reused some of the tailight and headlight harnesses, the rest was new.
rjones35
Postby Kingspeedy2 » Tue Jan 02, 2018 4:41 pm
I see some mention of Wire loom tape.I am not clear about this product.
It seems that there are cloth based ones and some vinyl.And they range greatly in price.some suggest using cloth hockey tape..not being a hockey player i woukdnt know the consistancy of that
Is the idea of these tapes is that it is self stick so it sticks to itself and not to the wire itself
As a protectinf layer ,anti rattle ant chafe sort of thingy??
I know even the best 3m electrical tape can leave a sticky residue i would like to avoid.
I was planning on using a lot of the woven and or split plastic covering as i am not going with a stock look
Kingspeedy2
Postby poboyjo65 » Tue Jan 02, 2018 5:01 pm
There is wrapping tape,here is one example;
https://www.amazon.com/Parts-Place-Adhe ... B00H87VJCQ
Might find it cheaper ,this was first I saw.
347, 4sp, 9''
JOHNO
Postby Kingspeedy2 » Wed Jan 03, 2018 7:13 am
Thanks Poboy for the Amazon Link that's exactly what I was looking for and ordered some up ...now why couldn't I find it
Kingspeedy2
Postby poboyjo65 » Wed Jan 03, 2018 1:34 pm
Kingspeedy2 wrote:Thanks Poboy for the Amazon Link that's exactly what I was looking for and ordered some up ...now why couldn't I find it
Maybe you were calling it the wrong thing? I think I just googled auto wire wrapping tape, I saw something that said harness wrapping tape & clicked on it.
One trick I use to find some things is, for instance, google ''oil sending unit wire connector pics'' , then click on ''images of oil sending unit wire connectors'', then look at the pics until I see the one I'm looking for,click on it,then it will say ''visit'' or ''visit page'' click on that & it will carry you to where the pic came from,most of the time it is a vender selling them. lots of times this is the only way I can find something.
347, 4sp, 9''
JOHNO
Postby tomb22 » Wed Jan 03, 2018 4:10 pm
I assembled the major wiring harness for the engine bay and used Flexo Pet expandable sleeve. The sleeve is 5/8" and will go from 3/8" to 1" in size. Pretty easy to work with and has a 240 degree melting point. They say to cut it with a heating knife but I cut it with a scissors and then just heat it up with a match to melt the ends to keep it from unraveling.
I will get some pictures of the install. This harness includes all the wiring for the lights, 2 electric fans, windshield washer pump, horns, fuse box feed, AC high pressure switch and security switch for the hood. The relay box is for the headlights and fans. Each filament has it's own 14 gauge wire.
Postby Kingspeedy2 » Thu Jan 04, 2018 7:25 am
great idea poboy for finding items,I also try other search engines besides google .google aslo has an image search function and it was amazingly quick.Thats how I found the relay enclosure I was looking for
Kingspeedy2
Postby tomb22 » Fri Mar 02, 2018 10:33 pm
I used Lou's suggestion about making the dash gauges removable by making a connection. Here are a couple of pictures showing what I did. The connections on the right are for the tach which will be on the dash. The pot is to make the led lights in the gauges dimmable and the 2 wire connection is for the speed sensor from the transmission.
This picture just shows the connectors in the dash.
Thanks for looking
Tom
Postby Lou's Comet » Sat Mar 03, 2018 8:00 am
Looks great Tom! Nice and clean, plus will make any future removal a lot easier.
What did you do about the high beam indicator light? Does your speedo have it built into it?
Postby tomb22 » Sat Mar 03, 2018 2:46 pm
Lou's Comet wrote:Looks great Tom! Nice and clean, plus will make any future removal a lot easier.
Thanks Lou. Yes my speedo actually has a high beam light and turn signal lights. I'm using the turn signal lights for notifying me when the cruise control is on and when I have the overdrive delete on. Here is a picture of the gauges.
Tom
Previous
Return to Body Shop
