what did you do to your comet today?
- gmsnowball
202 off the lift for now but looking for a manual transmission, bell housing, clutch, pressure plate, flywheel and throw out bearing and possibly a pilot bearing as well. Converting from an automatic to a standard. Wife’s idea, not mine.
Gary
Oklahoma Somewhere
Just Outside the Neutral Zone
64 Comet Calentie Convertible
Brought home my new 35 spline Strange case spool for my black car.
Atta boy Johno!!
Today it broke 70 degrees here in SE Wisconsin, I thought it would be a good day to fire up the Comet. Over the winter I replaced the rear main seal, installed a new clutch, did a few changes to the carburetors, installed a fuel pressure regulator W/ gauge and replaced the bearing type lower control arms with new conventional style. ( hoping the ride quality improves)
After priming the carburetors with the electric fuel pump the engine fired up and ran fine, the air/fuel ratio at idle is 13.6 so my carburetor changes have helped.
I have not put the car in the ground yet but a test drive is planned in the near future pending the weather. I do not have any events planned until next month so I have time to deal with any bugs that may arise.
All beauty Jim!
Including the shop ,especially all the air in there! I dont have room to fall down in my shop. I was out there today picking up some, my buddy came over,I was telling him my shop was like one of these old puzzles right now. have to move everything 4-5 times just to get started off right .
Jim what kind of regulator & gauge did you get? I got them a while back ,still in process of install. I'm kind of second guessing if I got the right reg for my set up.
Thanks guys. I try to keep my shop organized and somewhat clean, it does get messy and no matter how hard I try it still gets dirty. I need a cleaning lady!
The fuel regulator and gauge are from Summit. If you look at the engine photo you will see the gauge to the right of the distributor.
https://www.summitracing.com/parts/TSN-JM1057BK
https://www.summitracing.com/parts/HSE-5001-15-3
I have a high volume mechanical pump on the engine and an electric pump near the tank, the electric pump is on a manual switch and only operates when the engine has oil pressure.
I got this regulator , I've added a return line. I still need to make up a line from reg down to old line down by the frame ;
https://www.summitracing.com/parts/hly-12-881?rrec=true
& this gauge had a button that sounded important ,suckered me in.
https://www.summitracing.com/parts/aei-15632?rrec=true
& this pump;
https://www.summitracing.com/parts/tnk-gpa-tbi
Now I cant remember why I was second guessing one of them , pressures seem ok for a carb on all of it.
& this pump;
