Bench seat adjustment cable
Posted: Thu Feb 24, 2022 2:32 pm
by cyclonbrian
I took my front bench seat to the upholsterer to get it recovered about a month ago. I am ready to install it but when I looked the cable that goes from the adjuster lever to the other side does not look right. It is all attached but he hog ringed it to the from of the seat frame. This does not seem right. Does anyone have a picture or can tell me how the cable is to be routed? I does not look to just go strait across as the tranny tunnel hump would press on it.
Thank you for any help you can give
Brian
Re: Bench seat adjustment cable
Posted: Thu Feb 24, 2022 3:58 pm
yes that's how mine was, hog ring was not tight so the wire can move. this keeps it from dragging in the middle.
Posted: Thu Feb 24, 2022 7:02 pm
by cyclonbrian
Wow, ok, awesome.
Thanks a million.
I would be lost without this group!!
Posted: Thu Feb 24, 2022 7:25 pm
I said hog ring,but then got to thinking seems like I just unhooked from something when I took it off . looking at this illustration it shows a hook type thing which makes more sense,that way you could undo it if needed,& reattach easily. but I doubt that I would take the trouble to change the hogring unless it was too tight & wouldn't allow movement.
Posted: Thu Feb 24, 2022 11:58 pm
by cyclonbrian
Here is a picture of my seat. The cable is seen at the far right. The lever is at the bottom along with the tensioner.
- IMG_0063.jpg (139.28 KiB) Viewed 2616 times
Posted: Fri Feb 25, 2022 12:22 am
As long as it works I'd let er ride,wont be seen.
Posted: Fri Feb 25, 2022 10:24 am
by Caveman49
Looks good from what I’m seeing. I got a couple shots of mine, looks similar.
Posted: Fri Feb 25, 2022 10:48 am
by cyclonbrian
Caveman49 wrote: ↑Fri Feb 25, 2022 10:24 am
Do you have a photo of where the cable goes in the front middle of the seat?
Thank you
Posted: Fri Feb 25, 2022 1:17 pm
by Caveman49
The best I can do right now. The wire has a little play, not much.
Posted: Fri Feb 25, 2022 1:24 pm
by Caveman49
Mine looks like it’s going through one ring, where yours looks like it goes through several. Like John said, “if it works leave it as is,”
I agree. Is it binding or is it operating smooth?
Posted: Fri Feb 25, 2022 1:43 pm
by cyclonbrian
Perfect!!!! Exactly what I needed to see.
Thank you so much!!
Posted: Fri Feb 25, 2022 1:44 pm
by Caveman49
Glad to help.
Posted: Tue Mar 01, 2022 1:36 pm
by cyclonbrian
thanks everyone. Got the seat installed and it works perfectly.
Posted: Tue Mar 01, 2022 5:54 pm
by Caveman49
That’s good to hear, glad it worked out.
