Frame building question.......
Posted: Thu Apr 27, 2017 9:11 am
Hi everyone, its been a while since I have been on here with info on my 60 comet project gasser im building. Last time I was on here was when I was taking out the front end and I had ground down the front section of the frame and boxed it in and plated it with 1/8 flat stock and was to the point of looking for a motor. Well, I found one and it was not what I was looking for which was a sb motor either being a ford or chevy, no, I had to come across something ALOT bigger with a ton of torque and hp, stock. I found a 69 caddy 500ci motor. The specs on the motor are far more then I planned but sounds like it might be alot more fun once I wedge this thing in there, lol. Im now to the point to building a, I guess would call a 3/4 frame with 2x3 box tubing because the front is already boxed in and I think ready to go, so from there I plan on building one to the rear of the car and im thinking of going with a 4 link. So back to the front part as you can see in the pics, I need to build torque boxes of some sort and some cross bracing. I am VERY hesitant on doing this because im not sure what im doing, but I have been doing some research. I came up with the idea of putting in the front piece from the 2x3 outwards to the inner rocker. I plan on getting some 1/8 X 6 flat stock to go from the front of the inner rocker to the rear for extra support. The inner and outter rockers are very solid but would like to just stiffen it up a little more. Also, im going to go up the floor pan to the fire wall about 6in with the plate as well for extra in the front part. Like I said, im not really sure what im doing so if anyone wants to chime in with suggestions, please feel free to do so. So, from the front outside corner of the front brace where it meets the inner rocker, im going to put in another brace at an angle towards the other side of the car, kinda building a X frame kinda deal. Anyways, if anybody has anything, let er rip tater chip. Thanks
JUST TRIED TO POST PICS AND IT SAID QUOTA IS FILLED UP SO I GUESS I CANT SHOW YOU WHAT IM TALKING ABOUT BUT I HOPE YOU CAN GET WHAT IM SAYING. SORRY
