Gasket for heater spacer on carb 144 6
KatKar60
Post by KatKar60 »
I have the carb to intake manifold gasket that mounts above the heater spacer but the one beneath it that sits directly on the manifold>I need that one. It looks more like a heat type gasket and is thicker. Where do I find one? This is for the 144 6 cylinder. Thanks.
Re: Gasket for heater spacer on carb 144 6
KatKar60
Post by KatKar60 »
Thanks, I'll give them a try!
KatKar60
Post by KatKar60 »
KatKar60
FYI Gasket for heater spacer on carb 144 6
Post by KatKar60 »
Nope....wrong gasket. Called Fel-Pro. Gasket no longer available. You have to make your own using Fel-Pro number 2499.
