61 Comet base, 144cu. carb spacer replacement
61 Waycrosscomet
Post by 61 Waycrosscomet »
One of the heater hose connectors on the carb spacer is deteriorated to the point where I don't feel safe trying to clamp a hose on it. I don't know if this car has the original carburetor or not, but I cannot find an identical spacer that does not have this little channel on top near the opening like what is on the car now. My question is can I use one of these after market spacers that has this channel on top? everything else is the same. The carb is a
series A0E, type 1BA, date K. Thanks, John.m
Re: 61 Comet base, 144cu. carb spacer replacement
You have the channel on yours? Or no channel?
If the replacement ones have it and you don't it shouldn't make a difference, the other way around I am not sure, it depends on what that port is doing.
I am not a carb expert at all, most of the stuff they do is magic to me :roll:
Performance rebuild on a BUDGET - Working on; 250-6, T-5, 8.8 LSD, MII, Air Ride - Whatever I do it will be awesome!
