Page 2 of 2
Re: 289 Compression Test
Posted: Fri May 20, 2022 11:54 am
by comethead
Lou's Comet wrote: ↑Fri May 20, 2022 8:29 am
comethead wrote: ↑Thu May 19, 2022 7:36 pm
Lou's Comet wrote: ↑Thu May 19, 2022 6:09 pm
When you did the compression test did you have the carb/throttle wired wide open?
Seen engines with worse run good long time.
I did have the throttle open for the driver side bank not the passenger side
I guess I’ll have to run the test again but the right way. operating temp, throttle open.
That’s good news though that you’ve seen this before and it wasn’t a death sentence! That’s the reason I’m on the fence about this is its running good but the numbers seem low.
Ill report back after a retest.
Thanks Lou!
Put the parts on it and have fun!
Lou I like your style! My buddy said the same thing!
Posted: Fri May 20, 2022 12:07 pm
comethead wrote: ↑Fri May 20, 2022 11:53 am
poboyjo65 wrote: ↑Fri May 20, 2022 1:11 am
Joe have you ever run anything like seafoam thru it ?
I did once a long time ago. Not sure if it did anything. Do you recommend it Johnnie?
I was just thinking if it had carbon build up around the valves might affect the numbers a little. & I hear the gas is crappier out there. Be cool to see if it helped the numbers any. I'm not necessarily recommending it though,I tried it too , but cant remember if it helped or not
. maybe there is something better for cleaning out carbon, seams like someone posted fairly recently about cleaning their pistons with something. Maybe Joe T.?
Posted: Fri May 20, 2022 1:10 pm
by Joe Travers
poboyjo65 wrote: ↑Fri May 20, 2022 12:07 pm
Yeah, Lucas Fuel System Cleaner. It contains a lot of nitrogen like the drip used in shops to 'de-carbon' fouled engines. Couldn't get the drip juice w/o a license so tried Lucas & it works well after a few tanks of fuel.
I was chasing a rattle, not a miss. Tried carbon cleaner, colder plugs & richer jetting to try and cover it up. Ended up being distributor curve problem.
Posted: Fri May 20, 2022 7:25 pm
by comethead
Thanks Joe thanks Johnnie!
I’ll do a little research and see what’s out there.
Cleaned the plugs and put it back together and it fired right up! Kinda hard to tear things apart when it runs so well
Posted: Fri May 20, 2022 8:20 pm
by Joe Travers
Hey Joe, I bought a dirt cheap scope online that I plug into the laptop to power. It runs off USB or Android power terminals.
Display runs off Microsoft camera app. You can take snapshots w/ it if you need to.
Pull a sparkplug and take a peek inside. Comes in handy for diagnosing w/o tearing down.
Joe II
Posted: Fri May 20, 2022 8:47 pm
by Jims65cyclone
I've got one of those cameras that connects to my cell phone. Records video or photos in color. Head is about 3/16" diameter on end of 10 ft cable. Got it off Amazon for about $10. Great for looking under the dash without standing on your head.
Posted: Sat May 21, 2022 10:00 am
by Rocket989
Yah, rerun it hot. For those engines, cold, the numbers are about right, 150 to 120 is a decent spread though. I’d say she’s a bit on the decline. You could do the squirt a wee bit of oil into cylinder thing to see if it jumps up on the lower cylinders. You have a leak down tester for the oil rings?
Do tell more about the 302 that’s been hanging out…!
Posted: Mon May 23, 2022 12:15 pm
by comethead
Joe Travers wrote: ↑Fri May 20, 2022 8:20 pm
Joe II
Thanks Joe!!
I happen to have one as well…kinda forgot I have it
Ill do some poking around in the engine to see what I see.
Posted: Mon May 23, 2022 12:22 pm
by comethead
Rocket989 wrote: ↑Sat May 21, 2022 10:00 am
I have a leak down tester. Gotta whip it out and run that test too.
The rebuilt 302 I have is nothing special. It’s out of a 68 mustang that a friend didnt have the will to finish. It’s a stock build with a mild cam. I bought it off him for $500 about 150 years ago. It’s been wrapped in the corner of the garage awaiting its day in the Comet!
Posted: Mon May 23, 2022 12:49 pm
by Joe Travers
comethead wrote: ↑Mon May 23, 2022 12:22 pm
'68 was a crazy year for small blocks. I've owned a couple over the years. Check the displacement stamp in the lifter valley and the casting number on the crankshaft. There was some mix and match going down when the 289 parts were being depleted and 302 coming online. One I had was a 302 block w/ 289 crank.
Posted: Mon May 23, 2022 7:28 pm
by comethead
Joe Travers wrote: ↑Mon May 23, 2022 12:49 pm
Very true Joe! Ill verify that once I move it to the front burner some day
