260 2x4
Posted: Wed Feb 21, 2024 2:00 pm
Before getting started on the 3x2 project I got a couple of old Carter AFBs model 3826. They are from a 1965/66 Buick Special with the 300ci V8. Frequently referenced as 400 cfm, the smallest AFB. Then I got an Edelbrock F28 manifold to go with them.
Now I’m working on the 3x2 setup but I wanted to get the 2x4 ready to go also. Didn’t take much.
Pic1- fuel log. Probably has no practical advantage but I like the old style. The clamps are designed so cannot dig into the rubber h/t to A/FX for the reference.
Pic2- progressive linkage. Aftermarket options are clunky and expensive so for a few dollars I made it from scratch. The upper pivot point on the front carb is for direct or 1:1 linkage.
Pic3 and 4- air cleaner. Nothing is made for the old 4-1/8 carbs especially not in 2x4 configuration. So I made a base plate from 1/8 aluminum. I like the look of a round air cleaner rather than oval. Filter element is 14x2 and the top is cast aluminum from Summit.
