MALLORY
MALLORY
HAS ANYONE USED THE NEW MALLORY HEI DIST.?? THE DIST. CAP IS HUGE!!, STROKED
Stroked
"Alabama Fan That Bleeds Ford Blue"
http://s1106.photobucket.com/albums/h380/rsbaker/
http://s1106.photobucket.com/albums/h38 ... %20Bronco/
64 Comet BFX Tribute
66 AC Cobra Webers
73 Bronco
66 AC Cobra Webers
73 Bronco
Re: MALLORY
It's sure great to see ya back,, Kinda missed all that YELLIN!!!
NO never used or even seen one
Re: MALLORY
I knew a girl by that name once think that's how it was pro-nounced best i recall,she was quite a shocker pops
Re: MALLORY
If you're talking about the GM cap on a Ford distributor well; it just ain't right! I'll never understand it. GM guys are hard enough to put up with let alone be caught using any of their stuff on a Ford.
LR
LR
Re: MALLORY
I built a 351W powered roadster for a friend that really wanted that distributor! We could never get it to run right,it didn't fit well either,had to grind the manifold,it finally ate itself up!!! I talked him into a MSD Ready-to-Run,works great! JMO,ROY.
Real Racecars have 3 pedals
Re: MALLORY
I have a proform hei. junk. shoulda known better. noticed it wobble from the beginning. had it replaced, same thing.about 5 thousand miles ,the pick up coil went out. took it apart, TWO piece shaft. I guess it was a gm with an extention. I think the wobble was caused by the two piece junk, & let the bushing wear out & hang on the pick ups. ate it self up.
Re: MALLORY
THAT'S JUST WHAT I'M TALKING ABOUT!! IT JUST DON'T LOOK RIGHT- LIKE SOME KIND OF CROSS BREED!! WELL I ORDERED IT WITH A LOT OF OTHER PARTS , SO I GUESS I'LL TRY IT. I'M BUILDING A NEW MOTOR FOR MY PARTS TRUCK; 30 OVER 94 351W HO ROLLER. STROKEDLip Ripper wrote:If you're talking about the GM cap on a Ford distributor well; it just ain't right! I'll never understand it. GM guys are hard enough to put up with let alone be caught using any of their stuff on a Ford.
LR
Stroked
66 AC Cobra Webers
73 Bronco
66 AC Cobra Webers
73 Bronco
