Another vin decode if you please
I found the door tag and it did match the numbers on the firewall. #3J29U518176, does this mean I have the 170 motor? What other info does the vin give me? Also, on the door tag above where the vin is there are some numbers they are 62C J 58 23G 52 3 3. Can anyone help with these numbers? Greatly appreciated.
Re: Another vin decode if you please
Your car is a 63 Comet S-22 2 DOOR SEDAN,It came with a 170ci 6.Paint code J is Carnival red,3 trans is 2 speed auto,rear axle 3 is 3.20:1 ratio,your car was G 28,July 28th. www.61Thriftpower.com has avin decoder also.Good Luck,Heath
Black 1993 Ford Lightning
Thank you, thank you Hillbilly, now I'm finally on track.
I made a mistake on the second number, its actually 62C l 58 23G 52 3 3. I'm not sure if it is an i or an l. That would be a different paint code right?
Yes that would be (I) castaillian gold,Kinda greenish gold metallic,same as my 63 Comet wagon.
