61 4dr. Underlayment prefrences
61 Waycrosscomet
Post by 61 Waycrosscomet »
So my 61 did not have any carpet. Just a vinyl flooring with jute underlayment.
Any recommendations for underlayment for the 61? I plan to just put down black vinyl flooring again. Not a fan of car carpet.
Also, the floor (pan) has been blasted, primed and painted with a tough marine paint.
There were manufacturer holes punched through the pan, looked like the holes the old fashioned can openers made, triangle shaped. odd.
At this time I plugged them with dum dum caulk. The other round holes have the rubber plugs in them.
I have heard people complain about the peel and stick underlayment. But don't know much about it.
thanks for any advice.....
power band
Re: 61 4dr. Underlayment prefrences
Post by power band »
' good to hear the swept wing '61 is on the finish side of the project, how about teaser pics'
probably had the ribbed rubber/vinyl carpet which may be available ? . I'm a fan of simple 'Boat Carpet' in black - easily cut and shaped to look like black pre-cut/molded.
Image . Image
in the '63 , large square (18/18"?) 'pressure sensitive' (sticky backed) commercial carpet squares, worked great with thick foam backing needs nothing behind it but colors limited.
have fun
power band
" holes punched through the pan, looked like the holes the old fashioned can openers made"
any chance it was on a frame straightening jig ?
have fun
61 Waycrosscomet
Still need some more advice on this.
Originally on top of the pan the manufacturer sprayed or brushed some sort of black tar? maybe about 1/16 inch thick., the painted. On top of that was
the fibrous jute fabric, then on top of that was the vinyl flooring. There was no carpet in this car, just a vinyl flooring, which I will replace with same.
I am a bit at a loss as to what I need to put down. Do I need some sort of buytl or tar type barrier before I put down a jute replacement?
And whats a good jute replacement? alot of people don't like the old jute stuff, yet they sell tons of it online.
