things WERE going good until...
O.K. I had the blinkers and accessories working fine until I started messing with the brake light switch again. I saw a small spark when removing wires, and now nothing is working. Checked the fuses and saw nothing blown. Any ideas? Also, what kind of ballist resistor should I put going to the coil, and should it be wired in line to it? Thanks
Re: things WERE going good until...
One of the wires on the brake switch is always hot,Check it with a test light,If you have no power to one of the wires ,You have a blown fuse.
Black 1993 Ford Lightning
