Searched but didn't find any responses exactly.
Can I get a 15 x 7, 4 5/8ths backspace, "styled rim" (mustang) from Scott Drake, with a BF Goodrich 205/60R15 to fit on the rear of my '63 Comet without modification of any sort (Rolling or grinding of w/w lip?)
BRuce
Tire/Rim Question
Re: Tire/Rim Question
I just put 15 x 8, 4.25" backspaced rims on my 67 with 225/60R15's - fit great - the tire could actually be 1/4" - 1/2" wider with no rubbing.
My rims are good old cragar s/s by the way
67 Comet
...hell yea it's fun
I don't really understand back spacing, so this is as close as I can get to an answer..
I bought one of these wheels for a spare, and had to use it, and it fit perfect. Jegs says 3.75" backspace.. Spare tire size 195/60-15
http://www.jegs.com/webapp/wcs/stores/s ... 555-671000
If your wheel is deeper into the well, it should be ok. If its farther out, it could be tight..
Hope that helps..
Hope that helps..
'63 Comet Hardtop
Bruce;it should fit,I did a 63.5 Falcon Sprint and we used an 8" wheel with the hub centered.You will need to remove the bottoming stop from the frame as it will contact your tires. ROY.
Hello again,
Looking for someone that has put the tire /rim combonation that I mentioned my original post...on a '63 Comet.
all other car types/years/tire rim sizes need not reply...Thanks!
"Can I get a 15 x 7, 4 5/8ths backspace, "styled rim" (mustang) from Scott Drake, with a BF Goodrich 205/60R15 to fit on the rear of my '63 Comet without modification of any sort (Rolling or grinding of w/w lip?)"
Comet Bruce
Comet Bruce
Good luk
Good luk
67 Comet
Well I answered my own question...
Just recieved my new Scott Drake Mustang "styled" 15x7 rim with 205/60/R15's and the fit on the '63 is porfect, no body/fender opening modifcations.
Come Bruce
Come Bruce
Cool!
I had never seen those rims on a Comet so glad it worked for you!
'63 Comet Hardtop
