Can’t remember where these go.
Where do these go, been too long.
- BBA2D1D1-605B-479F-AE0C-A355223EB303.jpeg (160.14 KiB) Viewed 2048 times
Re: Can’t remember where these go.
Before you put the bottom of the back seat in, these clips screw into the metal that comes up from the floor at the top next to the side panels. They kind of hold the side panels in place and give it a clean look.
Hope this helps
tom
Hope this helps
tom
That does help for sure. This car has been apart for a while now. I may have to get a picture if I can't figure it out. Thanks again.
Glad you knew that, Tom. They looked like the mounting brackets for a set of Venetian blinds to me.
The only reason I remembered is I didn't know what they were for either when I saw them laying in a box So I scratched my head for a couple of days
tom
tom
I just love that on the Comet forum somebody can post a random picture of some obscure part and within an hour somebody has explained exactly what it's for. Blows my mind. Good on ya!
When there's no way you can forger,you do forget. Put stuff in bags and mark the contents....it better be a full description or you can't figure out what you meant to write or as in my case,can't read my own writing.
Or you label everything as you take it off, then mock up the car and throw everything back in one bag when you take it off and can't remember what they are later Or the writing gets rubbed off because they jostle around in one big drawer you keep digging through for bolts etc. That is what mostly has happened to my bolts that I can't figure what they are for.vicegrip wrote:When there's no way you can forger,you do forget. Put stuff in bags and mark the contents....it better be a full description or you can't figure out what you meant to write or as in my case,can't read my own writing.
