I agree the repops are garbage. The best thing they do is plug that big hole.
Here’s a couple rebuild services https://www.bobsspeedometer.com/1/120/services.asp
https://www.clocksandgauges.com/gas-tan ... epair.html
I haven’t used either but found them searching awhile back when I took my tank out.
'65 Fuel Sending Unit
Re: '65 Fuel Sending Unit
LOL.Jims65cyclone wrote: ↑Fri Jun 05, 2020 10:02 pmGet one of these. Henry used it on 15 million Model T's.
And I can check octane by tasting the tip of that ting after dipping it in, yes?
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
kevin
the higher the octane,,,the faster gas will flow thru that tiny hole ( well it sounded good).. pop
Yes absolutely it will work perfectly. Mine does.
I got this one,worked perfect
https://www.autokrafters.com/p-9951-fue ... 9275a.aspx
I would suggest replacing or at least checking the gauge voltage regulator under the dash and definitely changing the brass float to a solid plastic piece....got that from Amazon.
Kevin
I replied to your PM
