Rocker Molding ?
Rocker Molding ?
I am stripping my car for body work and paint. I took the Stainless rocker molding off today and see there are clip fasteners I will have to replace. Can anyone point me to a source for the clips or suggest a workable alternative?
Re: Rocker Molding ?
You failed to mention the year/ model of your Comet.
If you have a ‘64 Cyclone Auto Krafters has these: https://www.autokrafters.com/Mercury-Cy ... a076a.aspx
They are reproduction so they may not fit as original, I do not believe they have the sealant like the factory clips. They are also very pricey.
Sorry my car is a 1965 Cyclone. The rocker molding is one piece that goes between the wheel wells below the door sill.A/FX wrote: ↑Sun Jun 21, 2020 11:06 pmYou failed to mention the year/ model of your Comet.
Here are some sources to check out:
https://mrgusa.com/fasteners/
https://www.autofastco.net/universal_ml ... eners.html
https://www.amkproducts.com/bulk-fasten ... ookup=8220
https://www.cometcentral.com/forum/view ... =8&t=15184
https://www.cometcentral.com/forum/view ... =9&t=15219
https://www.cometcentral.com/forum/view ... 23&t=15429
https://www.cometcentral.com/forum/view ... =9&t=15832
Good Luck!
Good Luck!
Thanks for the help Jim. This will be a great help!Jims65cyclone wrote: ↑Mon Jun 22, 2020 10:52 pmHere are some sources to check out:
Good Luck!
Over the last couple of months I went through and replaced all of my molding clips. I suggest you look at my post history - you will see quite a number of posts of my trying to find various clips. If you can't find one then re-post here or send me a PM - I suspect I can help.
I was able to find a source for every clip on the 1965 convertible with one exception: A retainer at the ends of the molding strip that rides on top of the door (just next to the belt-line weather stripping). The main clips in that channel I could find however I had to fabricate the end clips (on my car there were only two of them as they were used only on the doors (and not the quarter panels)).
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
kevin
Thanks. I got the rocker mouldings off without damage and have plenty of samples to show. I will read through your thread thanks for the tip.kevinshi wrote: ↑Tue Jun 30, 2020 1:38 pmOver the last couple of months I went through and replaced all of my molding clips. I suggest you look at my post history - you will see quite a number of posts of my trying to find various clips. If you can't find one then re-post here or send me a PM - I suspect I can help.
