1965 Door Hinge Bushings...
Posted: Wed Oct 15, 2014 1:52 pm
On my 1965 Caliente convertible I am in the process of replacing the door hinge pins, springs and bushings.
I pulled out the pin and bushings from one of the hinges (drivers side lower). I now observe some slight differences in the replacement kit parts vs what I have removed from the car. (I ordered from Melvin's however a call to Mac's indicates that their kit is exactly the same as the one Melvin's sent me - I have not checked elsewhere).
I can't find my dang calipers just now however it appears that:
_1) the replacement pin is identical in diameter to the one I have removed (the new pin is a bit longer but that seems immaterial).
_2) the replacement bushing differs in two respects:
___a) the new bushing is 1/4" long whereas the old bushing is 3/8" long. See this picture: http://1drv.ms/1ve4ao8
___b) the new bushing appears to have a slightly larger inside diameter than the old bushing. E.g. I can pretty easily pass either pin through the new bushing whereas both pins immediately bind when attempting to pass them through the old bushing.
Questions:
Bushing Length: I realize I can probably use the 1/4" bushing however I use this car a LOT so I prefer to have the repair be as robust as possible. Thus I prefer to use a 3/8" bushing as I figure more "meat" will hold up to more door swings over time. Does anyone know where I can get such a part?
Bushing Inside Diameter: I *think* the difference I am noticing is a function of the old bushing having been hammered into the hinge hole (thereby slightly reducing its diameter) whereas the new bushing has not yet been so abused... I'm thinking the slight difference here isn't material... under the theory that once I smash that sucker into the hinge hole it will be just as tight as the old bushing. Any contrary opinions or insight?
Thanks in advance!
kevin
Questions:
Thanks in advance!
kevin
