No dash lights
The Big Comets
kcomet67
No dash lights
Post by kcomet67 »
I have no dash lights in my 67. Could it be that all of the bulbs are blown? I have the blue light that shows when the high beams are on and the turn signal indicators work. Just nothing behind the speedo or other gauges.
1967 Comet 202. 289. Work in Progress
Re: No dash lights
The earlier cars have a designated circuit for the instrument lights from the headlight switch (blue/red stripe) w/ an in-line fuse.
Don't know about '66-'67.
Re: No dash lights
Have you checked your fuses?
Re: No dash lights
kcomet67 wrote:
Mon Jan 31, 2022 10:03 pm
They could all be blown. When was the last time they worked?
First thing I would try is the dash light dimmer/rheostat, turn/spin the headlight knob clockwise and see if the dash lights work/get brighter. If you spin it all the way clockwise till it clicks the dome lights should turn on.
If that doesn't work do as Jim said and check the fuse.
Still no lights then I would reach up under dash and pull a bulb, if the bulb is good then check the socket for power, that is if the socket is wired, if it goes into a printed circuit type board/sheet it might be harder to test for power. I think it should be wired, not sure when the printed circuits started.
Still no luck check the headlight switch. The spring on the rheostat could have broke or the rheostat could have gone bad.
The High beam and turn signal indicators work off different circuits. They have nothing to do with dash lights. But since they do work I would think is is safe to assume the dash ground is good and not worry if dash lights have ground. Since they all ( dash lights and indicator lights) go into same dash assembly.
kcomet67
Re: No dash lights
Post by kcomet67 »
Not sure when they last worked I just picked the car up a couple of days ago. Where is the fuse box at? I turned the knob back and still nothing. Does anyone have a fuse diagram by chance?
Re: No dash lights
Fuse box is up under the dash sorta behind the fresh air vent, mounted to the firewall. At least it is on our 66.
Lou has mentioned pretty much all the things to check. Matter of fact, it gives me a couple more areas to look, they’re not working for me either. Have not driven at night yet, still in my shop/garage waiting for some parts.
kcomet67
Re: No dash lights
Post by kcomet67 »
Thanks I will start there and see what I can figure out. I also noticed that my wipers don’t work.
JimsHot66
Re: No dash lights
Post by JimsHot66 »
kcomet67 wrote:
Tue Feb 01, 2022 10:48 am
:shock: :shock: Not the wipers!! :shock: :shock:
Lot's of info on wipers here... see the thread on Wiper Motor Replacement. Good Luck and feel free to reach out once you've started down the wiper rabbit hole. :)
kcomet67
Re: No dash lights
Post by kcomet67 »
Just what I wanted to hear Jim lol. Sounds like I will have fun with that issue. :D
kcomet67
Re: No dash lights
Post by kcomet67 »
Dash lights are fixed!! Had to wiggle the headlight switch and boom dash lights. Havent had any issues out of them since.
