A few pics of the headlight and horn relay harnesses installation. I mounted the VR case with relays to the right front face of the radiator support. I didn’t paint the VR case so it could match the old paint on my Comet.
Peaking through grill it doesn’t really look out of place
The new harness connects to the starter relay. Notice the small fuse holder just below
Horn relay and wiring tucked under the horizontal top edge of the radiator support just above the voltage regulator. It’s completely out of view unless you’re looking for it.
I installed 4 new standard halogen bulbs but the harness is capable of supporting four H4 type high heat/high wattage bulbs. The big improvement makes night driving safer. With all four lights on the road is lit up almost like daytime
