Radio Compatibility
- FuzzyDriver
Radio Compatibility
What radios will fit right in a 1964 Comet?
Other Comet years?
Other 1964 Mercury's?
1964 Falcon? Some other Falcon years? What about Mustang?
The "radio" (I have to use that term loosely) that was in my baby is a major head-shaker, but the post doesn't belong here.
Other Comet years?
OK...so she might need a little work.
Re: Radio Compatibility
Big ‘64 mercury radio’s fit ‘64 Comets using the normal face plate. Am/Fm radio’s use an unique faceplate but also interchange between big ‘64 Merc’s and ‘64 Comets. The factory Am/Fm radio was a rare option in ‘64, I once owned a ‘64 Parklane Marauder that had the Am/Fm option, my Cyclone also has that option although I do not have it installed in the car. My music comes from under the hood.FuzzyDriver wrote: ↑Fri Sep 01, 2023 1:35 amWhat radios will fit right in a 1964 Comet?
Other Comet years?
- Boss/Cyclone
- Site Admin
65-66 Mustang radio's fit too.
I believe the knob shafts are too short on those types. On a Comet they gotta go through the dash trim plate, on a Mustang they don’t.
I wonder if a guy like Tayman radio could add longer shafts on a Mustang unit?
- Boss/Cyclone
- Site Admin
You are right, I got it to work with different knobs. Can't remember from what, it was long ago.
- FuzzyDriver
You are correct. I got hold of a Falcon AM radio (Model 4TBD). Everything matched up except the shafts are too short, so this isn't going to work. Pushbuttons are different, but they fit through the opening OK.
- FuzzyDriver
If any of you guys have a Mercury radio that will fit properly in my '64, I'd appreciate it. I'd really like to get one put in.
Thanks.
Thanks.
- FuzzyDriver
I found a nice-looking Comet radio on eBay. But it's a 1965. model 5TPE, while the 1964 AM model is 4TME. Does anyone know for sure if a 1965 Comet AM radio will fit correctly in a 1964 Comet? The problem with the Falcon radio is that the knob shafts are too short. The photos of the 1965 Comet radio show shafts that are way longer than the Falcon, which is a good sign. Already bought one radio that doesn't fit (the Falcon radio) so don't really need more radios that don't fit heh heh.
Keep in mind that an AM radio face plate and an AM/FM face plate are not the same, you must have the correct face plate to install either radio. AM/FM radios are extremely rare, in ‘64 they used the same radio in Comets and big Mercurys, obviously the face plates were not the same.
Here is the AM/FM radio from my Cyclone.
- FuzzyDriver
Thanks for that informaion. I guess I need just an AM radio then. Unless somebody has both the AM/FM radio and the bezel for a 1964 Comet. It's amazing to me that if I had any year Comet EXCEPT a 1964, I wouldn't have an issue getting a modern replacement that would fit. I went through eight internet stores and they ALL skip 1964.
- FuzzyDriver
The 1965 Comet AM radio looks really nice. From what I am told by internet store people the bar between the dial and pushbuttons is what keeps a 1965 from fitting. Has anyone been successful cutting away the bezel bar and then putting in a 1965 radio?
Here is a ruff looking one on ebay;
https://www.ebay.com/itm/334859633711
I would cut the bezel unless you have a spare. they pop up now & then.
- FuzzyDriver
Thanks for the reply. Did you mean "I would cut the bezel unless I didn't have a spare"?
I see that the radio in the eBay link has "64 Comet" hand-written on it, but that sure doesn't look like a '64 Comet radio. According to the shop manual the 4TME radio put in the 1964 Comet was made by Motorola, not RCA. This cabinet is very different. Every Comet/Falcon/Mustang radio from the era that I've seen has the output transistor mounted in the front of the cabinet on the bottom-right corner. Here's the 1965 Comet radio on eBay that I am thinking about boogering up my bezel to get it to fit: https://www.ebay.com/itm/276255854106
Yea I meant I wouldn't cut my only bezel . Seems like I have heard the 65 shafts are too long or something. are you looking for one that works? or are you going to have modern guts put in one? I just had a guy in Mt Juliet Tn. rework mine with all new stuff -blutooth & all.
Have you tried any of the comet pages on facebook?
