WTB: 144 I6 Head and manifold
On my newly (ebay) purchased 62 4door comet, I found it to be rather noisy. I concluded that the exhaust manifold gasket was bad, but while replacing I noticed that the front tab on the head that the bolt goes into has been broke, so the manifold wasnt bolted on all the way, and in turn it has warped the manifold.
Im looking for a 144 manifold and head, I hear you can swap to a bigger head for more power, but honestly im not interested unless it will make it cheaper.
Thanks for any help you can offer me.
Pete,I am running a 170 head on my 144 but am told if you run a 200 or 250 head you must shave it to keep the Compression ratio the same.Shipping would probably pretty high on a head,so I would try to find one locally.I would try to stick to a 144 or 170 60-64 head.If you can't find one locally I could send you one reasonable.I know I have a 170 head and I believe a couple of 144s.Which ever route you go I would reccomend vatting them and a valve job.Later,Heath
19'62 2Dr. Sedan, Black with Red interior.
1962 Comet S-22,Champagne w/beige and white interior
Black 1993 Ford Lightning
sadly I have a 5.0 with tranny and wiring harness ready to put in something, but I really want t stick with the 6
Im liking the idea of the bigger head, Im going to have to hunt around for one.
the only conversion machine work needed is just planing it down to keep compresion up? do the 200 heads have the intake attached?
- cometcountry1974
- Contact:
- cometcountry1974
- Contact:
- cometcountry1974
- Contact:
Sorry, must of gotten rid of it. Have about everything else. Good luck. If you can't find what you are looking for I do know of a local salvage yard that had two complete 170's still in the cars, I am sure they will sell a head off one. No idea what they would want for them though. They also are only open on the weekends.
Elsberry, MO
Elsberry, MO
Pete ,I did find one on ebay.The price seems a little steep even with the reserve not being met.Its for a 144
http://cgi.ebay.com/ebaymotors/Ford-6-C ... enameZWDVW
That looks like a nice one, but shipping would be way up there, and the price like you said is high.
I did some JB weld engineering to the head I have, and to the manifold. Its drying right now, ive fixed a crackin a John Deere backho engine block and fixed a hole in a block of a 180hp motorcycle aluminum motor with jbweld, so hopefully it will work
2000 SVT Lightning
1964 2 door comet w/ EFI 5.0
1962 2 door comet w/ 144 I6
