‘64 Falcon Track Project
Re: 64 Falcon Project
Thanks for the info JH!
Here's a pic of a GT350. Not sure if they are originals or repops. They are kinda angled.
free photo hosting
My 302- stock C5 289 block .040 over.
'70 Boss 302 forged steel cross-drilled crank
Roys old H-beam 302 rods and main girdle (thanks buddy!)
Forged 10:1 pistons.
Stock heads ported polished with big stainless valves.(Not sure size )
Isky .540 lift/290 duration solid cam.
Roys old Victor Jr. intake.
Mallory dual point distributer tuned to Boss 302 specs.
Canton road race oil pan with windage tray.
I'm gonna top it with a rebuilt Holley 650 DP.
As strange as it sounds I never expressed any power needs to my builder. I just told him I need it to live at high RPMs.
I don't know what it'll put out as far as HP.
free photo hosting
Hey joe, sounds like a real spinner!
I ran stock 289 rods and crank in my circle tracker at 6700 + for several seasons
Without a problem, yours should be WAY STRONGER than mine.
Hope to get to see the car this winter when we are down there on holiday.
Alright Fred sounds like a plan! Your always welcome to stop by...no chopping things up this time!
Yes I'm just hoping for a good reliable engine so I can go in circles at Willow Springs and learn how to drive the darn thing!
Check out some of RCMike's (search Mike Anderson)youtube vids of laps in his Datsun.
He has posted everywhere from the Snake to button and willow, even laps at fontana.
I dont know where it is but somewhere there is a vid of me driving his little red rocket
on the snake, checked off one on the bucket list that day!
You will have a great time going left and right, next to circle trackin road racin is my fav!
See you around the end of Jan,
Joe you sure do nice work that Falcon is going to look as nice as you Comet in no time.
Matt
Matt
Thanks Matt I really appreciate it. Glad your back!Loner wrote:Joe you sure do nice work that Falcon is going to look as nice as you Comet in no time.
Matt
Hey Fred I tried that search: nada!SASSY wrote:Check out some of RCMike's (search Mike Anderson)youtube vids of laps in his Datsun.
But there are some cool vids of Datsuns tearing up Willow!
Wow, that engine build looks awesome, good luck with the racing.
Thanks Albert !albert wrote:Wow, that engine build looks awesome, good luck with the racing.
Joe - I'd use a known good carb for your initial start-up! Shucks...grab the Autolite off of the Comet; it'll be fine to break the cam in. I've had to switch-a-roo vs. risking crankin' to much. And dump a bit of gas down whatever carb if it's sat a bit. You wanna get that beast started and over 2K RPM!
This is some damn good advice Rocketman!Rocket989 wrote:Joe - I'd use a known good carb for your initial start-up! Shucks...grab the Autolite off of the Comet; it'll be fine to break the cam in. I've had to switch-a-roo vs. risking crankin' to much. And dump a bit of gas down whatever carb if it's sat a bit. You wanna get that beast started and over 2K RPM!
& Joe if you think changing a carb a couple times is a lot of trouble think about how aggravating changing a cam ,lifters ,bearings & gaskets again!
Good idea guys. I'll do that!
Still pushing through sheetmetal hell!
Almost there bubba!Rocket989 wrote:Ugh - finish that junk up man!!!
Just need to wrap up the shock tower plates. Clean up the floors and add the bottom supports that the fool before me cut out and threw away, mini tubs and cage. That's it!
"Junk" is right !Rocket989 wrote:Ugh - finish that junk up man!!!
