Hey folks -
I am seeking a pair of the inside door panel lower trim pieces used on the 65 Caliente convertible. MPC tells me this same trim was used on the 65 2 Dr. Hardtop Calientes as well as the 65 Cyclone. The part number leads with C4GY so I suspect it also appeared on some of the 1964 models (I am quite sure one of you can tell me exactly where it appeared... ).
If you happen to have a set of these in please let me know - this is the only trim part missing from my otherwise complete 65 that is now getting close to full restoration...
65 Caliente Inner Lower Door Panel Trim
Thanks,
kevin
1965 Caliente Convertible
5H25A525287 (76DM6204L5416)
kevin
Re: 65 Caliente Inner Lower Door Panel Trim
i need the same if anyone has some extras?
