photo hosting site
photo hosting site
Photobucket is not free anymore. I tried using Google photos but seems I'm unable to share pic, just a link. I did find a bunch of old pics in my photobucket account.
What site are others using?
Roger
Roger
65 comet 7.61@96mph 1/8
Tweaked65 on instagram
https://youtu.be/JCVwEitXSi4
Re: photo hosting site
Been using post image,you can have it set to automatically resize your pics as you upload them. some tips on it in this thread:
https://cometcentral.com/forum/viewtopi ... age#p97068
use the ''Hot link to forums'' code
You can register at the CometCentral photo hosting site as well, I use the BBCode Full and keep the longest dimension of my pictures at 12" or less.
https://cometcentral.com/photos/
I had a problem with postimage. I will have to try again. I tried the comet central one and no luck getting on it.
Thanks guys
Thanks guys
I figured it out. Duh. Me and computers sometimes makes me crazy.
Roger
Nope I give up for tonight. It will only let upload if I upload as private.
Roger
On CometCentral photo site you can upload private (your albums are private) but links show here, just paste in the IMG code you copy from the photo site (it gives you a copy button) no other tags needed just paste it in the post as is, it should show then.
test
https://cometcentral.com/photos/image/gwnd
https://cometcentral.com/photos/images/ ... b72315.jpg
<img src="https://cometcentral.com/photos/images/ ... b72315.jpg" alt="2368ba5d969926b36e8fafae37b72315.jpg" border="0" />
hmmmm copy and paste but just get the link
Thanks Fred, I was using the embedded codes. I tried 3 different ones last try. Try,try again.
https://cometcentral.com/photos/images/ ... ba2efc.jpg
Just use the "Full Image"-"BBCode" under Embed codes;
When you hover over that with your mouse a "COPY" button appears on the right side, click it and just come back to your post and paste it, don't add any of the tags across the top of the edit window on the forum, when you click the Preview button you should see it.
Hey Mike, I've been using the "linked" one below your highlighted one, whats the diffference?
Just what I have been using
Look the same to me, maybe there is a load difference? By the time I scrolled down they were both loaded
