Introduce myself
Eddiecomet
Re: Introduce myself
Post by Eddiecomet »
A better picture of Helen, that’s the name my wife gave her honoring her grandma.
Aloha Ed
Eddiecomet
Aloha Ed
Eddiecomet
I would like to run headers on my 65 comet. It is a 4 speed car with power steering. What header will work? Not much room. Aloha Ed
Lots a stuff in driveline on brakes, your V 8 spindles are great same as Mustang. Early Kelsey/Hayes disc brake stuff is good, cheap, are widely available.
Use a 15/16s bore master cylinder and power booster not needed. Lots a guys here have used this combination including me.
A lot of guys use the CSRP conversion kits:
http://www.discbrakeswap.com/Mustang%20 ... SWAP1.html
Life is much easier if you install an export brace to replace the shock tower braces. Gives a lot more room for the MC/booster. Also makes general engine access better.
https://www.ebay.com/sch/i.html?_from=R ... t&_sacat=0
15x7x3.75BS TTII's all around
right on ,,,,!! helen is a good handle for a 65 comet....I knew a GIRL in the 5th grade by that name...she was the sexist thing in elementary school...but the little heifer wouldn't give me the time of day :shock: and even back then POP was COOL !!..... :shock: :shock: :lol: pop
You probably rode your bike like you drive a car, and she was skeered of you! :shock: :lol: :lol:
Eddiecomet
Any word on what headers fit the best without any or little modifications? I’ve been looking at long tube, hugger headers, but not really comfortable with what I am reading out there. I would like feed back on those that have installed a good set that fits great but yet, don’t breaks the bank. Thanks for the information on the K/H disc brakes. In the swap1 kit, is the master cylinder a 15/16” bore? I will be making an order soon. Thanks also on the x-brace. My Comet x-brace looks cheap and looks welded on. Aloha and mahalo from Hawaii, Ed
Johnnydarkgt350
Post by Johnnydarkgt350 »
Hello, Comet and high performance Ford enthusiasts; my name is Jim Wahl,; I have owned two 1964, cyclones; I currently have a 1965, cyclone four-speed with California black plates, also Previously a 1966, cyclone GT 390 and a 1967, cyclone GT 390 California black plate. My current 65 cyclone is an original DSO 52 Los Angeles district , original polar white and an original four-speed car, The car was built September 19th 1965 , original “ A “ code 289 , block cast September 9th 1965 and is a early six bolt . Engine is out going through upgrades but will still be the original “289” . It needs the dash bezels restored? Any help please? And correct tachometer? I’m building it more as a era correct time capsule, with acceptable mods of the sixties for stoplight meetings in Pomona California on a Saturday night cruise.
Welcome aboard! :D
Eddiecomet
I have a hardtop and a donor convertible. The front spring are different diameter. The convertible has a little bigger coil spring. Both are v8 cars. Question, Should I run the bigger diameter springs or the smaller one. I don’t know the spring rating. Any information is greatly appreciated!
Aloha Ed
Answer would depend on driving style, desired ride height.
Eddiecomet
Aloha all,
Sorry for such a long time not posting anything. We did start taking apart the front end and prepping to weld up the sock tower braces and cleaning and painting the engine bay. we also pulled the rear end and got that switched out but still need to install the axles and rear drum brakes. I got the disc brake conversion and will install after all the welding and drilling for the drop top A-arm are done. We also pulled out the power pack from the donor car and set the engine on the stand to start working on dressing up the engine. It's been raining so haven't had much time to work on the project. Will send picture soon, if I still remember how? Does anyone have a 3/4 shifter rod and lever for a Borg Warner T-10 four speed? I know there is a parts place on this site but forgot how to get there. I'm getting old and having a lot of senior moments! Thanks again, Ed
Eddiecomet wrote:
Mon Dec 28, 2020 3:28 pm
You may get a hit if you post down in the 'Wanted' section on the Home Index page.
EBay may be your best bet if you're looking for used Hurst pieces.
1963 Custom Hardtop HP 289/ T-10 4-speed
Eddiecomet
Thank JT!
I was thinking about a Hurst shifter but kind of want to stay original.
Mahalo, Ed
