Sloppy gear shift (automatic)
lwhuggins
Post by lwhuggins »
The gear shift on my '66 is sloppy. Is there any way to tighten this back up?
Re: Sloppy gear shift (automatic)
where is it sloopy at?? the handle or ???? need MO INFO !! POP
Like Pop said, mo info! like what shifter? floor or column? what trans?
Boatmangc
Post by Boatmangc »
Following this thread, my '67 is loose too, I looked at it last weekend thinking maybe knock out the roll pin and add a wave washer, mine has a wallowed out hole....
1967 Caliente Hardtop Small Block
Factory A/C
Factory Front discs
Factory AM/FM
